[Mapserver-users] Re: trouble using FILTER in PostGIS query
Jeff Hoffmann
jeff at propertykey.com
Wed May 21 12:13:47 EDT 2003
Jeff Hoffmann wrote:
> I'm trying to figure out how to set a FILTER on a PostGIS query based on
> a query parameter passed in from the URL. I tacked the parameter on the
> end of the URL ("&pin=13929111046") then added the following line in the
> mapfile:
> FILTER "parcel = '%pin%'"
> but nothing happens. When I looked at the actual query that is being
> sent to the database, it appears that the "%pin%" never gets translated
> into the value from the request. Am I doing this right? And if so, why
> isn't it working?
I think I found the answer on my own. I'm trying to do this with a WMS
layer, which apparently isn't supported now (see
http://lists.gis.umn.edu/pipermail/mapserver-dev/2003-January/000034.html).
Does anybody know if there is support for it yet in CVS?
Jeff Hoffmann
PropertyKey.com
