[Mapserver-users] availability of Ming with Mapserver 3.x...
Vincent Schut
schut at sarvision.com
Thu May 22 06:19:26 EDT 2003
I don't know about 3.6.x
You can use ming & 3.7. Usually 3.7 is quite stable, I use it all the time. Be
prepared, however, to stumble on some bugs... But the added features imho
outweigh the possibility of bugs.
For 3.7, you will need the newest version of GD (2.0.12).
I think you don't need the ming source, but you do need the ming lib. I'm not
sure about this, however, as I compiled ming myself so I don't have tried it
without having the source.
If you want to know why 'nothing happened', take a good look at the output of
the ./configure command when compiling mapserver. Actually, I think this
always is a good habit ;-) It gives you a lot of information about how
mapserver will be compiled and what options will be available or not, and can
save you from a lot of frustration afterwards.
Regards,
Vincent Schut.
On Thursday 22 May 2003 11:53, Benoit Lathiere wrote:
> Hello !
> I would like to use the Ming (Flash) output capability of Mapscript.
> I try to compile the 3.6.5 with "--with-ming=yes" argument but nothing
> happend... I tried with the mapserv-dev ; but I've ot an error with th GD
> library :-(
> So, my questionq are :
> Is Ming output available with Mapserver 3.6.5 ? if Yes, is the Ming source
> required for the compilation ?
> If Ming is only available with Mapserver 3.7, can I use the mapserver_dev
> package or must I waiting for the 3.7 version ?
> When is planned the 3.7 (stable) version ?
> Thanks a lot,
> Benoit Lathiere.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
