[Mapserver-users] availability of Ming with Mapserver 3.x...
Yewondwossen Assefa
assefa at dmsolutions.ca
Thu May 22 09:52:19 EDT 2003
Hi There,
Benoit Lathiere wrote:
> Hello !
> I would like to use the Ming (Flash) output capability of Mapscript.
> I try to compile the 3.6.5 with "--with-ming=yes" argument but nothing happend...
> I tried with the mapserv-dev ; but I've ot an error with th GD library :-(
> So, my questionq are :
> Is Ming output available with Mapserver 3.6.5 ? if Yes, is the Ming source required for the
> compilation ?
It is only available in the 3.7 version.
> If Ming is only available with Mapserver 3.7, can I use the mapserver_dev package or must I waiting
> for the 3.7 version ?
> When is planned the 3.7 (stable) version ?
You can use the current developpment version which is BTW stable :). There is work in progress to
stabilize it more and a release should be done pretty soon hopefully.
> Thanks a lot,
> Benoit Lathiere.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
