[Mapserver-users] PLEASE HELP...
Becher, Richard
RichardBecher at SierraSystems.com
Thu May 22 09:56:52 PDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C32083.247845C4
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Thanks for your reply!
=20
However, I have done all that you mentioned. =20
=20
Here is the entry in my map file:
=20
CONNECTIONTYPE oraclespatial
CONNECTION 'user/password at db'
DATA "LatLongPoint from CRHP_SPATIAL"
=20
There is definitely data in the table. Like I said there are no errors
but the data does not display on my map.
=20
I am retrieving the whole table just to see if I can display anything
right now.
=20
Any other ideas as to why my data won't display?
=20
Cheers,
=20
Richard
=20
-----Original Message-----
[mailto:Michael.Smith at erdc.usace.army.mil]=20
Sent: Thursday, May 22, 2003 11:17 AM
To: Becher, Richard; Mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] PLEASE HELP...
=20
Richard,=20
=20
Mapserver needs to be compiled with the oracle libraries
=20
i.e. --with-oraclespatial =3D /path/to/oracle/home
=20
Then, in the map file use=20
=20
CONNECTION 'user/password at tnsname' <mailto:'user/password at tnsname'>=20
DATA 'sdo_geometry_column FROM tablename'
=20
I've also found that if you use this format for the DATA line, that
mapserver will only select data with the extents of you map view, if you
use 'sdo_geom_col from (select * from tablename)' which is also valid,
on every redraw you will be retrieving the entire data table and not
using a spatial index.
=20
You do not have to use OGR to access Oracle. OGR is slower at this point
but does support more features (attribute queries mainly).=20
=20
Another importtant point is to increase the ARRAY_SIZE in the
maporaclespatial.c code. By default, it is set at 1, but we get much,
much faster performance by increasing the ARRAY_SIZE to 500 or 1000.
Basically this allows mapserver to send 500 ot 1000 rows at a time.=20
=20
Mike Smith=20
email: michael.smith at erdc.usace.army.mil=20
RSGISC=20
ERDC - CRREL=20
Hanover, NH 03755=20
(603) 646-4765=20
From: Becher, Richard [mailto:RichardBecher at SierraSystems.com]=20
Sent: Thursday, May 22, 2003 10:17 AM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] PLEASE HELP...
Importance: High
I have not been able to get a response on how to display data
using Mapserver from Oracle.
=20
I have created a connection to my Oracle db and I do not get any
errors.
=20
However, the data does not display.
=20
I was told that I can't do this direct connection to Oracle and
that I have to use OGR.
=20
Can someone please confirm this and give me any help on how to
simply display data from my Oracle database using Mapserver?
=20
Any help would be GREATLY appreciated.
=20
Cheers,
=20
Richard Becher
Sierra Systems
130 Slater Street, Suite 800
Ottawa, Ontario K1P 6E2
Phone: 613.236.7888, Extension: 350
Fax: 613.236.9333
Email: RichardBecher at SierraSystems.com
www.SierraSystems.com <http://www.sierrasystems.com/>=20
=20
=20
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C32061.9D56BDD0">
<title>Message</title>
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"time"/>
<o:SmartTagType =
name=3D"date"/>
<o:SmartTagType =
name=3D"PostalCode"/>
<o:SmartTagType =
name=3D"State"/>
<o:SmartTagType =
name=3D"City"/>
<o:SmartTagType =
name=3D"place"/>
<o:SmartTagType =
name=3D"Street"/>
<o:SmartTagType =
name=3D"address"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle18
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle21
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Thanks for your =
reply!<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>However, I have done all that you
mentioned.<span style=3D'mso-spacerun:yes'> =
</span><o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Here is the entry in my map =
file:<o:p></o:p></span></font></p>
style=3D'font-size:
<p class=3DMsoNormal =
style=3D'mso-layout-grid-align:none;text-autospace:none'><font
size=3D2 face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:"Courier New"'>CONNECTIONTYPE
<span class=3DSpellE>oraclespatial</span><o:p></o:p></span></font></p>
'user/<span =
class=3DSpellE>password at db</span>'<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3D"Courier New"><span =
font-family:"Courier New"'>DATA "<span =
class=3DSpellE>LatLongPoint</span>
from CRHP_SPATIAL"<o:p></o:p></span></font></p>
font-family:"Courier New"'><o:p> </o:p></span></font></p>
font-family:"Courier New"'>There is definitely data in the table.<span
style=3D'mso-spacerun:yes'> </span>Like I said there are no errors =
but</span></font><font
style=3D'font-size:10.0pt;font-family:Arial;
color:navy'> </span></font><font size=3D2 face=3D"Courier New"><span
style=3D'font-size:10.0pt;font-family:"Courier New"'>the data does not =
display on
my map.<o:p></o:p></span></font></p>
font-family:"Courier New"'>I am retrieving the whole table just to see =
if I can
display anything right now.<o:p></o:p></span></font></p>
font-family:"Courier New"'>Any other ideas as to why my data won’t
display?<o:p></o:p></span></font></p>
font-family:"Courier New"'>Cheers,<o:p></o:p></span></font></p>
font-family:"Courier New"'>Richard<o:p></o:p></span></font></p>
style=3D'font-size:
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'>-----Original =
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> Smith, Michael =
ERDC-CRREL-NH
[mailto:Michael.Smith at erdc.usace.army.mil] <br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> =
</span></font><st1:date
Month=3D"5" Day=3D"22" Year=3D"2003"><font size=3D2 face=3DTahoma><span =
style=3D'font-size:
10.0pt;font-family:Tahoma'>Thursday, May 22, =
2003</span></font></st1:date><font
style=3D'font-size:10.0pt;font-family:Tahoma'> </span></font><st1:time
Hour=3D"11" Minute=3D"17"><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>11:17 AM</span></font></st1:time><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'><br>
<b><span style=3D'font-weight:bold'>To:</span></b> Becher, Richard;
Mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> RE: =
[Mapserver-users]
PLEASE HELP...</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D3 =
face=3D"Times New Roman"><span
style=3D'font-size:12.0pt'><o:p> </o:p></span></font></p>
<div>
color=3Dblue face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Richard, =
</span></font><o:p></o:p></p>
</div>
<div>
style=3D'font-size:12.0pt'> <o:p></o:p></span></font></p>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Mapserver needs =
to be
compiled with the oracle libraries</span></font><o:p></o:p></p>
</div>
<div>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>i.e. =
=3D /path/to/oracle/home</span></font><o:p></o:p></p>
</div>
<div>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Then, in the map =
file use
</div>
<div>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'> CONNECTIONT=
YPE
oraclespatial<br>
CONNECTION '<a =
href=3D"mailto:'user/password at tnsname'">user/password at tnsname'</a><br>
DATA 'sdo_geometry_column FROM =
tablename'</span></font><o:p></o:p></p>
</div>
<div>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>I've also found =
that if
you use this format for the DATA line, that mapserver will only select =
data
with the extents of you map view, if you use 'sdo_geom_col from (select =
* from
tablename)' which is also valid, on every redraw you will be retrieving =
the
entire data table and not using a spatial =
index.</span></font><o:p></o:p></p>
</div>
<div>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>You do not have =
to use
OGR to access Oracle. OGR is slower at this point but does support more
features (attribute queries mainly). </span></font><o:p></o:p></p>
</div>
<div>
</div>
<div>
style=3D'font-size:10.0pt;font-family:Arial;color:blue'>Another =
importtant point
is to increase the ARRAY_SIZE in the maporaclespatial.c code. By =
default, it is
set at 1, but we get much, much faster performance by increasing the =
ARRAY_SIZE
to 500 or 1000. Basically this allows mapserver to send 500 ot 1000 rows =
at a
time. </span></font><o:p></o:p></p>
</div>
<div>
</div>
<div>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D1 =
face=3DArial><span
style=3D'font-size:7.5pt;font-family:Arial'>Mike Smith</span></font> =
<br>
<font size=3D1 face=3DArial><span =
style=3D'font-size:7.5pt;font-family:Arial'>email:
michael.smith at erdc.usace.army.mil</span></font> <br>
style=3D'font-size:7.5pt;font-family:Arial'>RSGISC</span></font>
<br>
style=3D'font-size:7.5pt;font-family:Arial'>ERDC -
CRREL </span></font><br>
style=3D'font-size:7.5pt;font-family:Arial'>Hanover,
NH 03755</span></font> <br>
style=3D'font-size:7.5pt;font-family:Arial'>(603)
646-4765</span></font> <o:p></o:p></p>
</div>
<blockquote =
style=3D'margin-top:5.0pt;margin-right:0in;margin-bottom:5.0pt'>
style=3D'mso-margin-top-alt:0in;margin-right:0in;margin-bottom:
12.0pt;margin-left:.5in'><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>-----Original Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> Becher, Richard
[mailto:RichardBecher at SierraSystems.com] <br>
style=3D'font-size:
Hour=3D"10" Minute=3D"17"><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>10:17 AM</span></font></st1:time><font size=3D2 =
face=3DTahoma><span
<b><span style=3D'font-weight:bold'>To:</span></b> =
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
HELP...<br>
<b><span style=3D'font-weight:bold'>Importance:</span></b> =
High</span></font><o:p></o:p></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>I have not been able to get =
a
response on how to display data using Mapserver from =
Oracle.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>I have created a connection =
to my Oracle
db and I do not get any errors.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>However, the data does not =
display.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>I was told that I can't do =
this
direct connection to Oracle and that I have to use =
OGR.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Can someone please confirm =
this and
give me any help on how to simply display data from my Oracle database =
using
Mapserver?<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Any help would be GREATLY
appreciated.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Cheers,<o:p></o:p></span></f=
ont></p>
face=3DArial><span
nt></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><strong><b><font =
size=3D3
color=3Dgreen face=3D"Times New Roman"><span =
style=3D'font-size:12.0pt;color:green;
mso-no-proof:yes'>Richard =
Becher<o:p></o:p></span></font></b></strong></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><em><b><i><font size=3D3 =
color=3Dgreen
style=3D'font-size:12.0pt;color:green;font-weight:
bold;mso-no-proof:yes'>Sierra Systems</span></font></i></b></em><b><font
color=3Dgreen><span =
style=3D'color:green;font-weight:bold;mso-no-proof:yes'><br>
</span></font></b><st1:Street><st1:address><font size=3D2 =
color=3Dnavy><span
style=3D'font-size:10.0pt;color:navy;mso-no-proof:yes'>130 Slater
Street, Suite 800</span></font></st1:address></st1:Street><font
color=3Dnavy><span style=3D'color:navy;mso-no-proof:yes'><br>
</span></font><st1:place><st1:City><font size=3D2 color=3Dnavy><span
style=3D'font-size:10.0pt;color:navy;mso-no-proof:yes'>Ottawa</span></fon=
t></st1:City><font
size=3D2 color=3Dnavy><span =
style=3D'font-size:10.0pt;color:navy;mso-no-proof:yes'>,
</span></font><st1:State><font size=3D2 color=3Dnavy><span =
color:navy;mso-no-proof:yes'>Ontario</span></font></st1:State><font =
size=3D2
style=3D'font-size:10.0pt;color:navy;mso-no-proof:yes'> =
</span></font><st1:PostalCode><font
style=3D'font-size:10.0pt;color:navy;mso-no-proof:yes'>K1P
6E2</span></font></st1:PostalCode></st1:place><font color=3Dnavy><span
</span></font><font size=3D2 color=3Dnavy><span =
mso-no-proof:yes'>Phone: 613.236.7888, Extension: 350</span></font><font
style=3D'font-size:10.0pt;color:navy'><o:p></o:p></span></font></p>
color=3Dnavy
yes'>Fax: 613.236.9333</span></font><font color=3Dnavy><span =
mso-no-proof:yes'>Email: =
RichardBecher at SierraSystems.com</span></font><font
mso-no-proof:yes'><a =
href=3D"http://www.sierrasystems.com/">www.SierraSystems.com</a></span></=
font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
<p class=3DMsoAutoSig style=3D'margin-left:.5in'><font size=3D3 =
style=3D'font-size:12.0pt;mso-no-proof:yes'><o:p> </o:p></span></fon=
t></p>
</blockquote>
</div>
</body>
</html>
=00
------_=_NextPart_001_01C32083.247845C4--
More information about the MapServer-users
