[Mapserver-users] PLEASE HELP...
Smith, Michael ERDC-CRREL-NH
Michael.Smith at erdc.usace.army.mil
Thu May 22 13:09:31 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C32084.E8DC9D10
Content-Type: text/plain
Are you sure that the locations are correct in the sdo_geometry? e.g. are the lat longs correct.
1. do a select * from crhp_spatial where rownum=1, look at the coords and verify
2. Is there a projection defined for the layer and map.
3. Make sure there is a class defined for the layer.
4. If you are using 3.7(4.0), add a log parameter to your web section and put debug as a line in your map layer.
Hope this helps
Mike Smith
email: michael.smith at erdc.usace.army.mil
RSGISC
ERDC - CRREL
Hanover, NH 03755
(603) 646-4765
-----Original Message-----
From: Becher, Richard [mailto:RichardBecher at SierraSystems.com]
Sent: Thursday, May 22, 2003 12:57 PM
To: Smith, Michael ERDC-CRREL-NH; Mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] PLEASE HELP...
Thanks for your reply!
However, I have done all that you mentioned.
Here is the entry in my map file:
CONNECTIONTYPE oraclespatial
CONNECTION 'user/password at db'
DATA "LatLongPoint from CRHP_SPATIAL"
There is definitely data in the table. Like I said there are no errors but the data does not display on my map.
I am retrieving the whole table just to see if I can display anything right now.
Any other ideas as to why my data won't display?
Cheers,
Richard
From: Smith, Michael ERDC-CRREL-NH [mailto:Michael.Smith at erdc.usace.army.mil]
Sent: Thursday, May 22, 2003 11:17 AM
To: Becher, Richard; Mapserver-users at lists.gis.umn.edu
Richard,
Mapserver needs to be compiled with the oracle libraries
i.e. --with-oraclespatial = /path/to/oracle/home
Then, in the map file use
CONNECTION 'user/password at tnsname' <mailto:'user/password at tnsname'>
DATA 'sdo_geometry_column FROM tablename'
I've also found that if you use this format for the DATA line, that mapserver will only select data with the extents of you map view, if you use 'sdo_geom_col from (select * from tablename)' which is also valid, on every redraw you will be retrieving the entire data table and not using a spatial index.
You do not have to use OGR to access Oracle. OGR is slower at this point but does support more features (attribute queries mainly).
Another importtant point is to increase the ARRAY_SIZE in the maporaclespatial.c code. By default, it is set at 1, but we get much, much faster performance by increasing the ARRAY_SIZE to 500 or 1000. Basically this allows mapserver to send 500 ot 1000 rows at a time.
Mike Smith
RSGISC
ERDC - CRREL
Hanover, NH 03755
(603) 646-4765
Sent: Thursday, May 22, 2003 10:17 AM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] PLEASE HELP...
Importance: High
I have not been able to get a response on how to display data using Mapserver from Oracle.
I have created a connection to my Oracle db and I do not get any errors.
However, the data does not display.
I was told that I can't do this direct connection to Oracle and that I have to use OGR.
Can someone please confirm this and give me any help on how to simply display data from my Oracle database using Mapserver?
Any help would be GREATLY appreciated.
Cheers,
Richard Becher
Sierra Systems
130 Slater Street, Suite 800
Ottawa, Ontario K1P 6E2
Phone: 613.236.7888, Extension: 350
Fax: 613.236.9333
Email: RichardBecher at SierraSystems.com
www.SierraSystems.com <http://www.sierrasystems.com/>
Content-Type: text/html
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word" xmlns:st1 =3D=20
"urn:schemas-microsoft-com:office:smarttags"><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3DUS-ASCII">
<TITLE>Message</TITLE>
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C32061.9D56BDD0" =
rel=3DFile-List><o:SmartTagType=20
name=3D"time"=20
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"></o:SmartTag=
Type><o:SmartTagType=20
name=3D"date"=20
name=3D"PostalCode"=20
name=3D"State"=20
name=3D"City"=20
name=3D"place"=20
name=3D"Street"=20
name=3D"address"=20
Type><!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<STYLE>st1\:* {
BEHAVIOR: url(#default#ieooui)
</STYLE>
<![endif]-->
<STYLE>@font-face {
font-family: Tahoma;
@page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; =
mso-header-margin: .5in; mso-footer-margin: .5in; mso-paper-source: 0; =
P.MsoNormal {
FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; =
mso-style-parent: ""; mso-pagination: widow-orphan; =
mso-fareast-font-family: "Times New Roman"
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlinkFollowed {
P.MsoAutoSig {
mso-pagination: widow-orphan; mso-fareast-font-family: "Times New =
Roman"
LI.MsoAutoSig {
Roman"
DIV.MsoAutoSig {
Roman"
SPAN.EmailStyle18 {
COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal; =
mso-style-noshow: yes; mso-ansi-font-size: 10.0pt; mso-bidi-font-size: =
10.0pt; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; =
mso-bidi-font-family: Arial
SPAN.EmailStyle21 {
COLOR: navy; FONT-FAMILY: Arial; mso-style-type: personal-reply; =
SPAN.SpellE {
mso-style-name: ""; mso-spl-e: yes
DIV.Section1 {
page: Section1
</STYLE>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]--></HEAD>
<BODY lang=3DEN-US style=3D"tab-interval: .5in" vLink=3Dpurple =
link=3Dblue>
<DIV><SPAN class=3D763570317-22052003><FONT face=3DArial =
color=3D#0000ff size=3D2>Are=20
you sure that the locations are correct in the sdo_geometry? e.g. are =
the lat=20
longs correct. </FONT></SPAN></DIV>
color=3D#0000ff=20
size=3D2></FONT></SPAN> </DIV>
color=3D#0000ff size=3D2>1. do=20
a select * from crhp_spatial where rownum=3D1, look at the coords and=20
verify</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff size=3D2>2. Is=20
there a projection defined for the layer and map.</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff size=3D2>3.=20
Make sure there is a class defined for the layer.</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff size=3D2>4. If=20
you are using 3.7(4.0), add a log parameter to your web section and put =
debug as=20
a line in your map layer.</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff size=3D2>Hope=20
this helps</FONT></SPAN></DIV>
<DIV> </DIV>
<DIV> </DIV>
<P><FONT face=3DArial size=3D1>Mike Smith</FONT> <BR><FONT face=3DArial =
size=3D1>email:=20
michael.smith at erdc.usace.army.mil</FONT> <BR><FONT face=3DArial=20
size=3D1>RSGISC</FONT> <BR><FONT face=3DArial size=3D1>ERDC - CRREL =
</FONT><BR><FONT=20
face=3DArial size=3D1>Hanover, NH 03755</FONT> <BR><FONT =
face=3DArial=20
size=3D1>(603) 646-4765</FONT> </P>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV></DIV>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr =
align=3Dleft><FONT=20
face=3DTahoma size=3D2>-----Original Message-----<BR><B>From:</B> =
Becher, Richard=20
[mailto:RichardBecher at SierraSystems.com] <BR><B>Sent:</B> Thursday, =
May 22,=20
2003 12:57 PM<BR><B>To:</B> Smith, Michael ERDC-CRREL-NH;=20
Mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> RE: =
[Mapserver-users]=20
PLEASE HELP...<BR><BR></FONT></DIV>
<DIV class=3DSection1>
<P class=3DMsoNormal><FONT face=3DArial color=3Dnavy size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Thanks for =
your=20
reply!<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: =
Arial"><o:p> </o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">However, I =
have done=20
all that you mentioned.<SPAN style=3D"mso-spacerun: yes"> =20
</SPAN><o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Here is =
the entry in=20
my map file:<o:p></o:p></SPAN></FONT></P>
<P class=3DMsoNormal style=3D"mso-layout-grid-align: none"><FONT=20
face=3D"Courier New" size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">CONNECTIONTYPE =
<SPAN=20
class=3DSpellE>oraclespatial</SPAN><o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">CONNECTION =
'user/<SPAN=20
class=3DSpellE>password at db</SPAN>'<o:p></o:p></SPAN></FONT></P>
<P class=3DMsoNormal><FONT face=3D"Courier New" size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">DATA "<SPAN=20
class=3DSpellE>LatLongPoint</SPAN> from=20
CRHP_SPATIAL"<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier =
New'"><o:p> </o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">There is =
definitely data=20
in the table.<SPAN style=3D"mso-spacerun: yes"> </SPAN>Like I =
said there=20
are no errors but</SPAN></FONT><FONT face=3DArial color=3Dnavy =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial"> =
</SPAN></FONT><FONT=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">the data does =
not display=20
on my map.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">I am retrieving =
the whole=20
table just to see if I can display anything right=20
now.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: 'Courier New'">Any other ideas =
as to why=20
my data won't display?<o:p></o:p></SPAN></FONT></P>
New'">Cheers,<o:p></o:p></SPAN></FONT></P>
New'">Richard<o:p></o:p></SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DTahoma =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">-----Original=20
Message-----<BR><B><SPAN style=3D"FONT-WEIGHT: bold">From:</SPAN></B> =
Smith,=20
Michael ERDC-CRREL-NH [mailto:Michael.Smith at erdc.usace.army.mil] =
<BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Sent:</SPAN></B> </SPAN></FONT><st1:date=20
style=3D"BACKGROUND-POSITION: left bottom; BACKGROUND-IMAGE: =
url(res://ietag.dll/#34/#1001); BACKGROUND-REPEAT: repeat-x"=20
Year=3D"2003" Day=3D"22" Month=3D"5"><FONT face=3DTahoma =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">Thursday, May 22,=20
2003</SPAN></FONT></st1:date><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma"> =
</SPAN></FONT><st1:time=20
Minute=3D"17" Hour=3D"11"><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">11:17=20
AM</SPAN></FONT></st1:time><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma"><BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">To:</SPAN></B> Becher, Richard;=20
Mapserver-users at lists.gis.umn.edu<BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Subject:</SPAN></B> RE: [Mapserver-users] =
PLEASE=20
HELP...</SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3D"Times =
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: =
12pt"><o:p> </o:p></SPAN></FONT></P>
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DArial =
color=3Dblue=20
size=3D2><SPAN style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: =
Arial">Richard,=20
</SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
12pt"> <o:p></o:p></SPAN></FONT></P></DIV>
<DIV>
color=3Dblue=20
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: blue; FONT-FAMILY: Arial">Mapserver =
needs to be=20
compiled with the oracle libraries</SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
<DIV>
color=3Dblue=20
Arial">i.e.=20
--with-oraclespatial =3D =
/path/to/oracle/home</SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
<DIV>
color=3Dblue=20
Arial">Then, in=20
the map file use </SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
<DIV>
color=3Dblue=20
size=3D2><SPAN=20
Arial"> CONNECTIONTYPE=20
oraclespatial<BR> CONNECTION '<A=20
href=3D"mailto:'user/password at tnsname'">user/password at tnsname'</A><BR>&n=
bsp;DATA=20
'sdo_geometry_column FROM =
tablename'</SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
<DIV>
color=3Dblue=20
Arial">I've=20
also found that if you use this format for the DATA line, that =
mapserver will=20
only select data with the extents of you map view, if you use =
'sdo_geom_col=20
from (select * from tablename)' which is also valid, on every redraw =
you will=20
be retrieving the entire data table and not using a spatial=20
index.</SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
<DIV>
color=3Dblue=20
Arial">You do=20
not have to use OGR to access Oracle. OGR is slower at this point but =
does=20
support more features (attribute queries mainly).=20
<DIV>
New Roman"=20
<DIV>
color=3Dblue=20
Arial">Another=20
importtant point is to increase the ARRAY_SIZE in the =
maporaclespatial.c code.=20
By default, it is set at 1, but we get much, much faster performance =
by=20
increasing the ARRAY_SIZE to 500 or 1000. Basically this allows =
mapserver to=20
send 500 ot 1000 rows at a time. </SPAN></FONT><o:p></o:p></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D1><SPAN=20
style=3D"FONT-SIZE: 7.5pt; FONT-FAMILY: Arial">Mike =
Smith</SPAN></FONT>=20
<BR><FONT face=3DArial size=3D1><SPAN=20
style=3D"FONT-SIZE: 7.5pt; FONT-FAMILY: Arial">email:=20
michael.smith at erdc.usace.army.mil</SPAN></FONT> <BR><FONT =
face=3DArial=20
size=3D1><SPAN style=3D"FONT-SIZE: 7.5pt; FONT-FAMILY: =
Arial">RSGISC</SPAN></FONT>=20
style=3D"FONT-SIZE: 7.5pt; FONT-FAMILY: Arial">ERDC - CRREL=20
</SPAN></FONT><BR><FONT face=3DArial size=3D1><SPAN=20
style=3D"FONT-SIZE: 7.5pt; FONT-FAMILY: Arial">Hanover, NH =20
03755</SPAN></FONT> <BR><FONT face=3DArial size=3D1><SPAN=20
style=3D"FONT-SIZE: 7.5pt; FONT-FAMILY: Arial">(603) =
646-4765</SPAN></FONT>=20
<BLOCKQUOTE style=3D"MARGIN-TOP: 5pt; MARGIN-BOTTOM: 5pt; =
MARGIN-RIGHT: 0in">
<P class=3DMsoNormal=20
style=3D"MARGIN-BOTTOM: 12pt; MARGIN-LEFT: 0.5in; MARGIN-RIGHT: =
0in; mso-margin-top-alt: 0in"><FONT=20
Message-----<BR><B><SPAN style=3D"FONT-WEIGHT: =
bold">From:</SPAN></B> Becher,=20
Richard [mailto:RichardBecher at SierraSystems.com] <BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Sent:</SPAN></B> =
size=3D2><SPAN=20
Minute=3D"17" Hour=3D"10"><FONT face=3DTahoma size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">10:17=20
style=3D"FONT-WEIGHT: bold">To:</SPAN></B>=20
style=3D"FONT-WEIGHT: bold">Subject:</SPAN></B> [Mapserver-users] =
PLEASE=20
HELP...<BR><B><SPAN style=3D"FONT-WEIGHT: =
bold">Importance:</SPAN></B>=20
High</SPAN></FONT><o:p></o:p></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT =
face=3DArial size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">I have not been able =
to get a=20
response on how to display data using Mapserver from=20
Oracle.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">I have created a =
connection to=20
my Oracle db and I do not get any =
errors.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">However, the data =
does not=20
display.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">I was told that I =
can't do this=20
direct connection to Oracle and that I have to use=20
OGR.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">Can someone please =
confirm this=20
and give me any help on how to simply display data from my Oracle =
database=20
using Mapserver?<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Arial">Any help would be =
GREATLY=20
appreciated.<o:p></o:p></SPAN></FONT></P>
Arial">Cheers,<o:p></o:p></SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><STRONG><B><FONT=20
face=3D"Times New Roman" color=3Dgreen size=3D3><SPAN=20
style=3D"FONT-SIZE: 12pt; COLOR: green; mso-no-proof: yes">Richard=20
Becher<o:p></o:p></SPAN></FONT></B></STRONG></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><EM><B><I><FONT=20
style=3D"FONT-WEIGHT: bold; FONT-SIZE: 12pt; COLOR: green; =
mso-no-proof: yes">Sierra=20
Systems</SPAN></FONT></I></B></EM><B><FONT color=3Dgreen><SPAN=20
style=3D"FONT-WEIGHT: bold; COLOR: green; mso-no-proof: =
yes"><BR></SPAN></FONT></B><st1:Street><st1:address=20
url(res://ietag.dll/#34/#1001); BACKGROUND-REPEAT: repeat-x"><FONT=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: yes">130 =
Slater=20
Street, Suite =
800</SPAN></FONT></st1:address></st1:Street><FONT=20
color=3Dnavy><SPAN=20
style=3D"COLOR: navy; mso-no-proof: =
yes"><BR></SPAN></FONT><st1:place><st1:City><FONT=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: =
yes">Ottawa</SPAN></FONT></st1:City><FONT=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: yes">,=20
</SPAN></FONT><st1:State><FONT color=3Dnavy size=3D2><SPAN=20
yes">Ontario</SPAN></FONT></st1:State><FONT=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: yes">=20
</SPAN></FONT><st1:PostalCode><FONT color=3Dnavy size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: yes">K1P=20
6E2</SPAN></FONT></st1:PostalCode></st1:place><FONT =
style=3D"COLOR: navy; mso-no-proof: yes"><BR></SPAN></FONT><FONT =
color=3Dnavy=20
size=3D2><SPAN style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: =
yes">Phone:=20
613.236.7888, Extension: 350</SPAN></FONT><FONT color=3Dnavy =
size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: =
navy"><o:p></o:p></SPAN></FONT></P>
face=3D"Times New Roman"=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; mso-no-proof: yes">Fax:=20
613.236.9333</SPAN></FONT><FONT color=3Dnavy><SPAN=20
color=3Dnavy=20
yes">Email:=20
RichardBecher at SierraSystems.com</SPAN></FONT><FONT =
color=3Dnavy=20
yes"><A=20
href=3D"http://www.sierrasystems.com/">www.SierraSystems.com</A></SPAN><=
/FONT><SPAN=20
style=3D"mso-no-proof: yes"><o:p></o:p></SPAN></P>
<P class=3DMsoAutoSig style=3D"MARGIN-LEFT: 0.5in"><FONT =
size=3D3><SPAN=20
style=3D"FONT-SIZE: 12pt; mso-no-proof: =
yes"><o:p> </o:p></SPAN></FONT></P>
size=3D3><SPAN=20
12pt"><o:p> </o:p></SPAN></FONT></P></BLOCKQUOTE></DIV></BLOCKQUOTE=
></BODY></HTML>
------_=_NextPart_001_01C32084.E8DC9D10--
