AniS, WAS: [Mapserver-users] availability of Ming with Mapser
ver 3.x...
Antti.Roppola at brs.gov.au
Fri May 23 00:01:24 EDT 2003
That is incredibly neat. It took all of 10 minutes to set up the
results of a growth model so that viewers can see the model run
and do light table style overlays with other opaque layers.
Shouldn't be a brain stretching exercise to integrate with
Mapserver apps.
Thankyou very much for posting that. :o)
Cheers,
Antti
-----Original Message-----
From: Charlton Purvis [mailto:cpurvis at asg.sc.edu]
Sent: Friday, 23 May 2003 12:50 AM
To: Yewondwossen Assefa; Benoit Lathiere
Cc: mapserver-users at lists.gis.umn.edu
Subject: AniS, WAS: [Mapserver-users] availability of Ming with
Mapserver 3.x...
Hi, folks:
I just checked the mailing list, and AniS never showed up. I've tried
flash, ming, gifsicle, and now AniS. AniS rocks! It is so easy if
applets are OK w/ you.
If you can create the MapServer images, animation is a snap.
Take the 2 seconds needed to visit their site for great documentation
and examples: http://www.ssec.wisc.edu/visit/AniS/anist1.html.
That tiny applet snipped is really all you need. Don't overlook adding
these, though (if you need to):
<APPLET codebase="/resources/anis" code="AniS.class" width=600
height=600>
<PARAM name="image_base" value="http://my.server.com/images/">
Charlton
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Thursday, May 22, 2003 9:52 AM
To: Benoit Lathiere
Subject: Re: [Mapserver-users] availability of Ming with Mapserver
3.x...
Hi There,
Benoit Lathiere wrote:
> Hello !
> I would like to use the Ming (Flash) output capability of Mapscript.
> I try to compile the 3.6.5 with "--with-ming=yes" argument but nothing
happend...
> I tried with the mapserv-dev ; but I've ot an error with th GD library
> So, my questionq are :
> Is Ming output available with Mapserver 3.6.5 ? if Yes, is the Ming
source required for the
> compilation ?
It is only available in the 3.7 version.
> If Ming is only available with Mapserver 3.7, can I use the
mapserver_dev package or must I waiting
> for the 3.7 version ?
> When is planned the 3.7 (stable) version ?
You can use the current developpment version which is BTW stable :).
There is work in progress to
stabilize it more and a release should be done pretty soon hopefully.
> Thanks a lot,
> Benoit Lathiere.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
