[Mapserver-users] Any One Plz?
Thorsten Fischer
thfischer at mapmedia.de
Fri May 23 06:33:59 PDT 2003
On Fri, 2003-05-23 at 11:54, Dwijadas Dey wrote:
> PROBLEM1:-
> I am using mapserver3.5 and new to it.
This version is outdated. You might want to try the latest version 3.6.x
> I have written the mapfile and
> template
> fie(both given below). In the template file in the [ ] portion, i
> have used the values directly. e.g in ["map"] i have given
> ["c:\program....\templ.map"]
Maybe this is just a typo here ... you do not write ["map"], but only
[map]. MapServer is scanning for certain keywords enclosed in [] and
replaces them. "map" is not a keyword, but map is.
Similar, ["c:\..."] does not work because "c:\" is not a keyword. Just
write c:\... here. In the template file below I see you've done it
correctly.
> SHAPEPATH "C:\Program Files\Apache Group\Apache2\htdocs\shape"
> FONTSET "C:\Program Files\Apache
> Group\Apache2\htdocs\fonts.list"
> SYMBOLSET "C:\Program Files\Apache
> Group\Apache2\htdocs\symbol\circle.sym"
> WEB
> TEMPLATE templ.html
> IMAGEPATH "C:\Program Files\Apache
> Group\Apache2\htdocs\images\"
> IMAGEURL ".\images\"
This means to check for a directory /image in the current working
directory, which is probably not what you want. If this directory is in
your webserver root directory, write "/images/"
> <input type="hidden" name="imgext" value= "2700051.860
> 2462746.020 3582564.801 3012459.468">
> <! <input type="hidden" name="mapext" value= "2700051.860
With hardcoding these variables, nothing will ever change, because you
will always have the same map extent, no matter if you zoom in or out.
This is a variable value. Try:
<input type="hidden" name="imgext" value="[mapext]">
> <input type="hidden" name="imgxy" value="199.5 149.5">
> <! <input type="hidden" name="imgxy" value="[imgxy]">
In case this is supposed to be a comment, HTML comments start with <!--
and have to be closed with --> again.
> <table border=1 cellpadding=3>
> <tr>
> <td align=center>
> <! THE PROBLEM IS HERE IN THE NEXT TWO LINE>
> <input type="image" name="img" src= "[img]">
> <! <input type="image" name="img" src= "c:\Program Files\Apache
> Group\Apache2\htdocs\images\">
You define an image but you give a directory name as a source. Nothing
will be displayed.
> </td>
> <td valign=top> <font size=+1 face=arial,helvetica>Map
> Controls</font>
> <center><p> Select layers to display:<br>
> <select multiple name="layer">
> <option value="assam_a"[assam_a_select]> District Head
> Quarters
> <option value="assm-rvr"[assm-rvr_select]> Rivers
> <option value="airport"[air_port_select]> Airports
This is a common error that happens to me surprisingly often too. You
need a space between the quote and the mapserver tags.
> <select name="zoom" size="1">
> <option value="10" [zoom_10_select]> Zoom in 10 times
> <option value="8" [zoom_8_select]> Zoom in 8 times
> <option value="4" [zoom_4_select]> Zoom in 4 times
> <option value="3" [zoom_3_select]> Zoom in 3 times
There is no option called zoom. You can define zoomdir, which gives the
direction of the zoom (1 zooms in, 0 stays at the current level and -1
zooms out). In addition, you can define zoomsize, which gives a factor
to use for zooming.
> <hr>
> <p align="center"><font
> face=arial,helvetica><b>Legend</b></font><br>
> <img src="c:/Program Files/Apache
> Group/Apache2/htdocs/lgnd/">
> <p align="center"> <img src="c:/Program Files/Apache
> Group/Apache2/htdocs/images/">
Again, you only give directory names.
> PROBLEM2:-(If i donot used the values inside [ ] directly)
> I have tried with [ ] also AS values between [ ] will filled up
> by the mapserver from URL and .map file. But it is giving an
> error message which is like "msLoadMap(): Unable to access file.
> Illegal mapfile name".
[snip]
> "[imgext]">
It's [mapext].
> Considering the CGI variable [map] in the template file,
> Mapserver should atleast know the value of the "map" then it
> should replace it. But from where and which portion of the mapfile
> the mapserver will find the value of map?????
map is the name of the mapfile. You give it as a parameter in the URL
that you use to call mapserver. In your template, you define
<input type="hidden" name="map" value="[map]">
So when using the form in the HTML file, the next call to mapserver will
include the value for map again.
> (Probably form NAME
> at the first line
> of the mapfile) then probably i have to give a mappath like
> shapepath?
NAME is only used as a prefix for generation temporary filenames.
> Please tell me from which portion of the map file these
> values([ ]) will come????
They are either taken/computed from the mapfile (like [imgxy] for
example, which is calculated by dividing the SIZE parameter by 2), or
they are provided via the URL (like [map] in most cases).
> whether these values will be within the
> WEB .....END structure ?? I am totally confused. I have gone
> through the Mapserver CGI variables which you refers in the
> mail.
Maybe you want to take a step backward and familiarize yourself with the
official Itasca demo package. You can download it from the mapserver
website.
hth,
thorsten
More information about the MapServer-users
