[Mapserver-users] Compilation problem
Till Adams
adams at terrestris.de
Fri May 23 06:44:28 EDT 2003
--------------060002010308010601050203
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Dear list,
I'm trying to compile ms-3.6.5 on mandrake again. Using
./configure --with-proj=/usr/local/ --with-gdal=/usr/local/bin
--with-php=/usr/local/include/php --with-gd=/usr/local --with-freetype
--with-ogr --with-gdal --with-wmsclient --with-wms
Everything works fine. When I type the "make" (tried both: Including the
"-lstdc++" Option in the Makefile and not), everything works nearly fine
but the process is stopping after a while giving the message:
"gcc: unrecognized option `-rdynamic-Wl'"
Nevertheless my "mapserv" file is created. Testing it with "./mapserv" I
get the following error-message:
"./mapserv: error while loading shared libraries: libproj.so.0: cannot
open shared object file: No such file or directory"
When I search for the file "libproj.so.0" I find it in "/usr/local/lib".
I installed LinPNG, LibTIFF, PROJ4, W3c-LibWWW, Freetype2, GD2, ...
Any ideas? Many thanks in advance :-) :-) :-) .
Second question: I used the manual from Yann and Prasad, posted several
weeks ago, but this is based on ms 3.7. Where can I get the pre-release?
Thanks in advance,
Till
***** Treffen Sie uns auf der AGIT in Salzburg vom 2. bis 4. Juli 2003, Stand 35 *****
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
<small><font face="Courier New, Courier, monospace"><big>D</big></font><font
face="Courier New, Courier, monospace">ear list,<br>
<br>
I'm trying to compile ms-3.6.5 on mandrake again. Using <br>
<br>
./configure --with-proj=/usr/local/ --with-gdal=/usr/local/bin --with-php=/usr/local/include/php
--with-gd=/usr/local --with-freetype --with-ogr --with-gdal --with-wmsclient
--with-wms<br>
<br>
</font></small><font face="Courier New, Courier, monospace"><small>"-lstdc++"
Option in the Makefile and not),</small></font><small><font
face="Courier New, Courier, monospace"> everything works <i>nearly</i> fine
but the process is stopping after a while giving the message:<br>
<br>
"gcc: unrecognized option `-rdynamic-Wl'"<br>
<br>
get the following error-message:<br>
<small><br>
</small></font><font face="Courier New, Courier, monospace">"./mapserv: error
while loading shared libraries: libproj.so.0: cannot open shared object file:
No such file or directory"<br>
<br>
I installed LinPNG, LibTIFF, PROJ4, W3c-LibWWW, Freetype2, GD2, ...<br>
<br>
Any ideas? Many thanks in advance <span class="moz-smiley-s1"><span> :-)
</span></span><span class="moz-smiley-s1"><span> :-) </span></span><span
class="moz-smiley-s1"><span> :-) </span></span>.<br>
<br>
Second question: I used the manual from Yann and Prasad, posted several weeks
ago, but this is based on ms 3.7. Where can I get the pre-release?<br>
<br>
Thanks in advance,<br>
Till<br>
</font></small>
<pre class="moz-signature" cols="$mailwrapcol"><small><font
</font></small>
<a class="moz-txt-link-abbreviated" href="mailto:info at terrestris.de">info at terrestris.de</a> * <a class="moz-txt-link-abbreviated" href="http://www.terrestris.de">www.terrestris.de</a></pre>
</body>
</html>
--------------060002010308010601050203--
