[Mapserver-users] Compilation problem
Lowell Filak
lfilak at medinaco.org
Fri May 23 08:18:12 EDT 2003
You probably already checked this but, is /usr/local/lib in /etc/ld.so.conf?
Lowell F.
The following message was sent by Till Adams <adams at terrestris.de> on Fri, 23 May 2003 12:44:28 +0200.
> Dear list,
> I'm trying to compile ms-3.6.5 on mandrake again. Using
> ./configure --with-proj=/usr/local/ --with-gdal=/usr/local/bin
> --with-php=/usr/local/include/php --with-gd=/usr/local --with-freetype
> --with-ogr --with-gdal --with-wmsclient --with-wms
> Everything works fine. When I type the "make" (tried both: Including the
> "-lstdc++" Option in the Makefile and not), everything works nearly fine
> but the process is stopping after a while giving the message:
> "gcc: unrecognized option `-rdynamic-Wl'"
> Nevertheless my "mapserv" file is created. Testing it with "./mapserv" I
> get the following error-message:
> "./mapserv: error while loading shared libraries: libproj.so.0: cannot
> open shared object file: No such file or directory"
> When I search for the file "libproj.so.0" I find it in "/usr/local/lib".
> I installed LinPNG, LibTIFF, PROJ4, W3c-LibWWW, Freetype2, GD2, ...
> Any ideas? Many thanks in advance :-) :-) :-) .
> Second question: I used the manual from Yann and Prasad, posted several
> weeks ago, but this is based on ms 3.7. Where can I get the pre-release?
> Thanks in advance,
> Till
> ***** Treffen Sie uns auf der AGIT in Salzburg vom 2. bis 4. Juli 2003, Stand 35 *****
> Dipl. Geogr. Till Adams
> terrestris, Paulsen&Adams GbR
> Siemensstr. 8 * 53121 Bonn
> Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> info at terrestris.de * www.terrestris.de
