[Mapserver-users] python mapscript 3.7/4.0
Michael Schulz
mschulz at webgis.de
Sat May 24 13:06:58 EDT 2003
i keep having problem with the python mapscript build with some newer
version of pymodule.i (v.1.2). The python setup_wnone.py build command
stops with:
"error: command 'gcc' failed with exit status 1"
If i use an older version of pymodule (1.1) the build process gives no
errors and python/mapscript is built and working properly. What could be
the problem?
Cheers, Michael
