[Mapserver-users] String the Atribute Data very long in Mapserv 4.0
Wilman Rojas
wilmanrojas at geoweb.com.co
Sat Nov 1 16:50:13 EST 2003
This is a multi-part message in MIME format.
--Boundary_(ID_awJVbOEmw+mskmNsF5mgzw)
Content-type: text/plain; charset=us-ascii
Content-transfer-encoding: 7BIT
Hi.
My problem is that set a attribute data of layer by a string of consult
very long and no work but in mapserv 3.6 if work.
Wilman Rojas.
Content-type: text/html; charset=us-ascii
<html xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:w="urn:schemas-microsoft-com:office:word" xmlns="http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii">
<meta name=ProgId content=Word.Document>
<meta name=Generator content="Microsoft Word 10">
<meta name=Originator content="Microsoft Word 10">
<link rel=File-List href="cid:filelist.xml at 01C3A098.37B04D40">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:UseFELayout/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:SimSun;
panose-1:2 1 6 0 3 1 1 1 1 1;
mso-font-alt:\5B8B\4F53;
mso-font-charset:134;
mso-generic-font-family:auto;
mso-font-pitch:variable;
mso-font-signature:3 135135232 16 0 262145 0;}
@font-face
{font-family:"\@SimSun";
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:SimSun;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
{margin:0cm;
font-size:10.0pt;
font-family:"Courier New";
span.EstiloCorreo17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 3.0cm 70.85pt 3.0cm;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
table.MsoNormalTable
{mso-style-name:"Tabla normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]-->
</head>
<body lang=ES link=blue vlink=purple style='tab-interval:35.4pt'>
<div class=Section1>
<p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;
font-family:Arial'><o:p> </o:p></span></font></p>
<p class=MsoNormal><span class=SpellE><font size=2 face=Arial><span
style='font-size:10.0pt;font-family:Arial'>Hi</span></font></span><font size=2
face=Arial><span style='font-size:10.0pt;font-family:Arial'>.<o:p></o:p></span></font></p>
<p class=MsoNormal><font size=2 face=Arial><span lang=EN-US style='font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>My problem is that set <span
class=GramE>a</span> attribute data of layer by a string of consult very long and
no work but in <span class=SpellE>mapserv</span> 3.6 if work.<o:p></o:p></span></font></p>
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p> </o:p></span></font></p>
<p class=MsoPlainText><font size=2 face="Courier New"><span style='font-size:
10.0pt;mso-no-proof:yes'>Wilman Rojas.<o:p></o:p></span></font></p>
<p class=MsoNormal><font size=3 face="Times New Roman"><span lang=EN-US
style='font-size:12.0pt;mso-ansi-language:EN-US'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
--Boundary_(ID_awJVbOEmw+mskmNsF5mgzw)--
