[Mapserver-users] getFeatureInfo on dynamic layer - empty
exception
Debbie Pagurek
pagurekd at agr.gc.ca
Mon Nov 3 10:40:49 EST 2003
Hi Frieso,
I will look into this a bit more carefully in a bit, but right off the
bat I wonder if you have a problem because you have named your layer
"wms" and maybe this is a reserved word. Try naming your layer
something else?
Debbie
>>> "Frieso ter Haseborg" <ter-haseborg at sf-datentechnik.de> 11/03/03
06:25AM >>>
Hi Debbie,
from the PHP/MapScript for dynamic layer creation you shared with us I
learned, that you're doing getFeatureInfos against a php-created layer.
Does the error description below sound similar to anything you ran
against during your development? Or are there any
configuration-differences in the mapfile compared to your approach?
Since there was low feedback from the list on this , I hope you could
give me a hint.
TIA,
Frieso
>-----Original Message-----
>From: Frieso ter Haseborg
>Sent: Tuesday, October 28, 2003 9:52 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] getFeatureInfo on dynamic layer - empty
>exception
>Hi,
>I ran into a problem doing a getFeatureInfo-request on a dynamic
layer.
>I've got a PHP/Mapscript-component to build dynamic layers, this
works
>well on getMap-requests. Trying to do a getFeatureInfo-request I get
>some strange results:
>When performin a request with a url like this:
>http://my.ip/cgi-bin/mapserv.exe?map=../htdocs/ims.map&version=
>1.1.0&req
>uest=getFeatureInfo&query_layers=wms&x=251&y=329&INFO_FORMAT=te
>xt/plain&
>BBOX=2574700,5752000,2589700,5767000
>I get an xml-doc with an empty exception statement:
><?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
><!DOCTYPE ServiceExceptionReport SYSTEM
>"http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd">
><ServiceExceptionReport version="1.1.0">
><ServiceException>
></ServiceException>
></ServiceExceptionReport>
>This is the corresponding part of the mapfile:
>LAYER
> NAME "wms"
> TEMPLATE test.html
> STATUS ON
> TYPE POLYGON
> CONNECTION "http://my.ip/kmvims/test4.php"
> CONNECTIONTYPE WMS
> TOLERANCE 3
> METADATA
> "wms_srs" "EPSG:26915 EPSG:42101 EPSG:4269 EPSG:4326
>EPSG:42304"
> "wms_name" "wms"
> "wms_title" "test"
> "wms_server_version" "1.1.0"
> "wms_formatlist"
"image/gif,image/png,image/jpeg,image/wbmp"
> "wms_format" "image/gif"
> "WMS_FEATURE_INFO_MIME_TYPE" "text/html"
> END
> OFFSITE 255 255 255
>END
>system-configuration: Win2k; Apache 2.0.47; MS 4.0; PHP 4.3.2,
>MapScript
>rev 1.177
>The getFeatureInfo-request works fine on my shape-layers but no
success
>on the dynamic layer. And what's oddest, the php in my dynamic layer
>seems not to be executed at all. When doing a getFeatureInfo-request
I
>do just a echo "test"; and log the get-Parameters into a logfile. But
>the log stays untouched, whereas the log works fine on the
>getMap-request. Any ideas?
>Any hint would be appreciated.
>TIA,
>Frieso ter Haseborg
>- Software Development -
>S&F Datentechnik GmbH&Co.KG
>Reimersstr. 41b
>26789 Leer, Germany
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
