[Mapserver-users] compiling regex on windows
bean at vt.edu
agillesp at vt.edu
Tue Nov 4 11:00:12 EST 2003
i'm now getting this:
Makefile.vc(50) : fatal error U1086: inference rule cannot have dependents
Stop.
-abe
>===== Original Message From Stephen Clark <stephen.clark at focus.ca> =====
>I have attached a copy of a windows makefile.vc I got from the list a while
>back.
>try this out.
>stephen
>----- Original Message -----
>From: "bean at vt.edu" <agillesp at vt.edu>
>To: "Mapserver-users" <Mapserver-users at lists.gis.umn.edu>; "Stephen Clark"
>Sent: Tuesday, November 04, 2003 7:03 AM
>Subject: RE: [Mapserver-users] compiling regex on windows
>> my regex only came with Makefile.in ... that's for *nix. am i missing
>> something?
>> -abe
>> >Heve you tried compiling using at a command window:
>> >nmake /f makefile.vc
>> >From: "Abram Gillespie" <agillesp at vt.edu>
>> >To: <Mapserver-users at lists.gis.umn.edu>
>> >Sent: Sunday, November 02, 2003 9:00 PM
>> >Subject: [Mapserver-users] compiling regex on windows
>> >> i'm trying to compile the regex lib on windows 2000 with vs.net. i get
>> >> the following error:
>> >> c:\source_code\regex-0.12\regex.c(63) : fatal error C1083: Cannot open
>> >> include file: 'strings.h': No such file or directory
>> >> then when i define HAVE_STRING_H to try to fix the above error i get
>> >> these:
>> >> c:\source_code\regex-0.12\regex.c(808) : error C2365: 're_set_syntax' :
>> >> redefinition; previous definition was a 'function'
>> >> c:\source_code\regex-0.12\regex.h(404) : see declaration of
>> >> 're_set_syntax'
>> >> c:\source_code\regex-0.12\regex.c(808) : error C2146: syntax error :
>> >> missing ';' before identifier 'reg_syntax_t'
>> >> c:\source_code\regex-0.12\regex.c(808) : fatal error C1004: unexpected
>> >> end of file found
>> >> anything i can do?
>> >> thanks.
>> >> abe
>> >> _______________________________________________
>> >> Mapserver-users mailing list
>> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
