[Mapserver-users] compiling regex on windows
Stephen Clark
stephen.clark at focus.ca
Tue Nov 4 13:34:00 EST 2003
Abe,
You have lost me on the problem with the error.
you might want to try:
nmake /f makefile.vc clean
nmake /f makefile.vc distclean
and then
hope this helps
Stephen
----- Original Message -----
To: "Mapserver-users" <Mapserver-users at lists.gis.umn.edu>; "Stephen Clark"
<stephen.clark at focus.ca>
Sent: Tuesday, November 04, 2003 8:00 AM
Subject: RE: [Mapserver-users] compiling regex on windows
> i'm now getting this:
> Makefile.vc(50) : fatal error U1086: inference rule cannot have dependents
> Stop.
> -abe
> >===== Original Message From Stephen Clark <stephen.clark at focus.ca> =====
> >I have attached a copy of a windows makefile.vc I got from the list a
while
> >back.
> >try this out.
> >stephen
> >From: "bean at vt.edu" <agillesp at vt.edu>
Clark"
> >Sent: Tuesday, November 04, 2003 7:03 AM
> >> my regex only came with Makefile.in ... that's for *nix. am i missing
> >> something?
> >> -abe
> >> >Heve you tried compiling using at a command window:
> >> >From: "Abram Gillespie" <agillesp at vt.edu>
> >> >To: <Mapserver-users at lists.gis.umn.edu>
> >> >Sent: Sunday, November 02, 2003 9:00 PM
> >> >Subject: [Mapserver-users] compiling regex on windows
> >> >> i'm trying to compile the regex lib on windows 2000 with vs.net. i
get
> >> >> the following error:
> >> >> c:\source_code\regex-0.12\regex.c(63) : fatal error C1083: Cannot
open
> >> >> include file: 'strings.h': No such file or directory
> >> >> then when i define HAVE_STRING_H to try to fix the above error i get
> >> >> these:
> >> >> c:\source_code\regex-0.12\regex.c(808) : error C2365:
're_set_syntax' :
> >> >> redefinition; previous definition was a 'function'
> >> >> c:\source_code\regex-0.12\regex.h(404) : see declaration of
> >> >> 're_set_syntax'
> >> >> c:\source_code\regex-0.12\regex.c(808) : error C2146: syntax error :
> >> >> missing ';' before identifier 'reg_syntax_t'
> >> >> c:\source_code\regex-0.12\regex.c(808) : fatal error C1004:
unexpected
> >> >> end of file found
> >> >> anything i can do?
> >> >> thanks.
> >> >> abe
> >> >> _______________________________________________
> >> >> Mapserver-users mailing list
> >> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
