[Mapserver-users] zoom and pan problem -- help need
Daniel Morissette
morissette at dmsolutions.ca
Tue Nov 4 11:21:20 EST 2003
Murat Isik wrote:
> *Fatal error*: MapServer Error in msCalculateScale(): Invalid image
> extent. in
> */var/www/html/mapserver/itasca/demo_try_mysql_alpha_zoom.php* on line *95*
> This is the line about extent. I have bolded it below. Please help me
> understand what is going wrong. Any ideas?
I couldn't see line 95 in bold, but anyway you normally get this error
if your extents or your map width/height result in a map with 0-width or
0-height so you need to make sure the values you set for your extents
are valid (perhaps print the values before setting the extents).
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
