[Mapserver-users] revisiting compiling regex on windows
bean at vt.edu
agillesp at vt.edu
Wed Nov 5 14:33:58 EST 2003
This is the preamble of a multipart MIME formatted message.
If you are reading this text your mail system is most likely
not capable of properly decoding MIME messages. To extract
the contents of this message, save it to a file and then use
an external MIME decoding utility.
--mime-boundary-interchange-3fb1ca89
Content-Type: text/plain; charset="ISO-8859-1"
Content-Transfer-Encoding: 7bit
someone mentioned posting my entire regex compiling process (sorry, that
email's at home). not much involved, just two steps. i've included the
output and my Makefile.vc.
thanks again for the help with this.
-abe
***** begin output *****
C:\Documents and Settings\abe\Desktop\Temp\regex-0.12>"C:\Program
Files\Microsof
t Visual Studio\VC98\Bin\vcvars32.bat"
Setting environment for using Microsoft Visual C++ tools.
C:\Documents and Settings\abe\Desktop\Temp\regex-0.12>nmake /f Makefile.vc
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
for d in doc test; do (cd $d; NMAKE CPPFLAGS='-DHAVE_STRING_H
-DREGEX_M
ALLOC' CFLAGS='-Ox -G6' CC='cl' DEFS='' LDFLAGS='' LOADLIBES='' default);
done
d was unexpected at this time.
NMAKE : fatal error U1077: 'for' : return code '0x1'
Stop.
Content-Type: application/octet-stream; name="Makefile.vc"
Content-disposition: attachment; filename="Makefile.vc"
Content-Transfer-Encoding: BASE64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--mime-boundary-interchange-3fb1ca89--
