[Mapserver-users] Dyanic Point with Zoom
Brian Cunningham
BRC at capindex.com
Wed Nov 5 15:18:13 EST 2003
Hello all-
I am stuck and can't figure out what Im doing wrong. I am trying to
pass Lat/Long coords which will create a point and zoom to that point.
What happens is it zooms to the right coords but the created point
object doest show. I figure maybe something is missing or in the wrong
order. I have browsed the archive listing and from what I gather it
looks right...
Below is everything
Thanks in advance!
Brian
#Point Layer
LAYER
NAME "point_layer"
TYPE point
STATUS on
CLASS
NAME 'point_layer'
STYLE
COLOR 0 0 255
SIZE 27
SYMBOL 'circle' #(*note: my circle is
defined in a symbol set file)
END
END
END
<html>
<?php
dl('php_mapscript.dll');
$map_path="../htdocs/";
//CREATE INSTANT OF mapOBJECT
$map = ms_newMapObj($map_path."test3.map");
$image = $map->prepareImage();
$image=$map->draw();
// CREATE NEW layerObject
$pt_layer = ms_newLayerObj($map);
$pt_layer = $map->getLayerByName("point_layer");
$pt_layer->set("status", 1);
//SET NEW POINT OBJECT
$pt = ms_newPointObj();
//Pass static coords
$lon = -73; /*User input*/
$lat = 46; /*User input*/
//SET POINT OBJECT
$pt->setXY($lon, $lat);
$pt->draw($map, $pt_layer, $image, 0, "");
$pt_layer->set('status', MS_ON);
$pt_layer->draw($image);
// ZoomPoint - zooooom to point
$map->zoompoint(75,$pt,$map->width,$map->height,$map->extent);
//Create web image
$image_url = $image->saveWebImage(MS_PNG,1,1,0);
<html>
<HEAD>
<TITLE>POINT CREATION</TITLE>
</HEAD>
<BODY>
<CENTER>
<form name="form1" method="get">
<center><h1>POINT
CREATION</h1></center><br>
<INPUT TYPE=IMAGE NAME="img"
SRC="/tmp/ms_tmp/<?php echo $image_url; ?>">
</form>
</CENTER>
</BODY>
</HMTL>
