[Mapserver-users] Dyanic Point with Zoom
Eric Bridger
eric at gomoos.org
Wed Nov 5 10:52:43 EST 2003
Brian,
There is really no need to call $pt_layer->draw(). You already called
$pt->draw(). Just a guess, but try removing the layer->draw().
Actually, now that I look at, no need to call $map->draw() either. You
should just call $map->prepareImage(), $pt->draw(), then
$image->saveWebImage().
HTH
On Wed, 2003-11-05 at 20:18, Brian Cunningham wrote:
> Hello all-
> I am stuck and can't figure out what Im doing wrong. I am trying to
> pass Lat/Long coords which will create a point and zoom to that point.
> What happens is it zooms to the right coords but the created point
> object doest show. I figure maybe something is missing or in the wrong
> order. I have browsed the archive listing and from what I gather it
> looks right...
> Below is everything
> Thanks in advance!
> Brian
> #Point Layer
> LAYER
> NAME "point_layer"
> TYPE point
> STATUS on
> CLASS
> NAME 'point_layer'
> STYLE
> COLOR 0 0 255
> SIZE 27
> SYMBOL 'circle' #(*note: my circle is
> defined in a symbol set file)
> END
> END
> END
> <html>
> <?php
> dl('php_mapscript.dll');
> $map_path="../htdocs/";
> //CREATE INSTANT OF mapOBJECT
> $map = ms_newMapObj($map_path."test3.map");
> $image = $map->prepareImage();
> $image=$map->draw();
> // CREATE NEW layerObject
> $pt_layer = ms_newLayerObj($map);
> $pt_layer = $map->getLayerByName("point_layer");
> $pt_layer->set("status", 1);
> //SET NEW POINT OBJECT
> $pt = ms_newPointObj();
> //Pass static coords
> $lon = -73; /*User input*/
> $lat = 46; /*User input*/
> //SET POINT OBJECT
> $pt->setXY($lon, $lat);
> $pt->draw($map, $pt_layer, $image, 0, "");
> $pt_layer->set('status', MS_ON);
> $pt_layer->draw($image);
> // ZoomPoint - zooooom to point
> $map->zoompoint(75,$pt,$map->width,$map->height,$map->extent);
> //Create web image
> $image_url = $image->saveWebImage(MS_PNG,1,1,0);
> <html>
> <HEAD>
> <TITLE>POINT CREATION</TITLE>
> </HEAD>
> <BODY>
> <CENTER>
> <form name="form1" method="get">
> <center><h1>POINT
> CREATION</h1></center><br>
> <INPUT TYPE=IMAGE NAME="img"
> SRC="/tmp/ms_tmp/<?php echo $image_url; ?>">
> </form>
> </CENTER>
> </BODY>
> </HMTL>
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
