[Mapserver-users] Dyanic Point with Zoom
Brian Cunningham BRC at capindex.com
Wed Nov 5 13:21:44 PST 2003
When I remove $image=$map->draw(); the point draws but it is not located
in the center and my other layer does not show up, which does show with
the $map->draw().
Is there something wrong with my map file?
MAP
	NAME TEST
	STATUS ON
	SIZE 600 450
	SYMBOLSET ../etc/symbols.sym
	EXTENT -141.017718 41.679738 -52.619173 83.115060
	UNITS DD
	SHAPEPATH "../data"
	IMAGECOLOR 204 204 204
	FONTSET ../etc/fonts.txt
	WEB
		TEMPLATE MapTemplate.html
		IMAGEPATH "/tmp/ms_tmp/"
	END
#Tab layers
	LAYER
		NAME prv
  		TYPE POLYGON
		CONNECTIONTYPE OGR
		CONNECTION "../data/prv.tab"
		STATUS DEFAULT
 		CLASS
	   		OUTLINECOLOR 0 255 0
	   		COLOR 204 255 153
		END
	END # Layer
	LAYER
		NAME "point_layer"
		TYPE point
		STATUS on
		CLASS
			NAME 'point_layer'
			STYLE
				COLOR 0 0 255
				SIZE 27
				SYMBOL 'circle'
			END
		END
	END
END
-----Original Message-----
Sent: Wednesday, November 05, 2003 10:53 AM
To: Brian Cunningham
Cc: Mapserver List
Subject: Re: [Mapserver-users] Dyanic Point with Zoom
Brian,
There is really no need to call $pt_layer->draw().  You already called
$pt->draw().  Just a guess, but try removing the layer->draw().
Actually, now that I look at, no need to call $map->draw() either. You
should just call $map->prepareImage(), $pt->draw(), then
$image->saveWebImage().
HTH
On Wed, 2003-11-05 at 20:18, Brian Cunningham wrote:
> Hello all-
> I am stuck and can't figure out what Im doing wrong.  I am trying to
> pass Lat/Long coords which will create a point and zoom to that point.
> What happens is it zooms to the right coords but the created point
> object doest show.  I figure maybe something is missing or in the
> wrong order.  I have browsed the archive listing and from what I
> gather it looks right... Below is everything
> Thanks in advance!
> Brian
> #Point Layer
> 	LAYER
> 		NAME "point_layer"
> 		TYPE point
> 		STATUS on
> 		CLASS
> 			NAME 'point_layer'
> 			STYLE
> 				COLOR 0 0 255
> 				SIZE 27
> 				SYMBOL 'circle' #(*note: my circle is
> defined in a symbol set file)
> 			END
> 		END
> 	END
> <html>
> <?php
> 	 dl('php_mapscript.dll');
> 	 $map_path="../htdocs/";
> 	//CREATE INSTANT OF mapOBJECT
> 	 $map = ms_newMapObj($map_path."test3.map");
> 	 $image = $map->prepareImage();
> 	// CREATE NEW layerObject
>   	$pt_layer = ms_newLayerObj($map);
> 	$pt_layer = $map->getLayerByName("point_layer");
> 	$pt_layer->set("status", 1);
> 	//SET NEW POINT OBJECT
> 	$pt = ms_newPointObj();
> 	//Pass static coords
> 	$lon = -73;	/*User input*/
> 	$lat = 46;	/*User input*/
> 	//SET POINT OBJECT
> 	$pt->setXY($lon, $lat);
> 	$pt->draw($map, $pt_layer, $image, 0, "");
> 	$pt_layer->set('status', MS_ON);
> 	$pt_layer->draw($image);
> 	// ZoomPoint  - zooooom to point
> 	$map->zoompoint(75,$pt,$map->width,$map->height,$map->extent);
> 	//Create web image
> 	$image_url = $image->saveWebImage(MS_PNG,1,1,0);
> 		 <html>
> 		 <HEAD>
> 		 <TITLE>POINT CREATION</TITLE>
> 		 </HEAD>
> 		 <BODY>
> 		 <CENTER>
> 		<form name="form1" method="get">
> 						<center><h1>POINT
> CREATION</h1></center><br>
> 		              <INPUT TYPE=IMAGE NAME="img"
SRC="/tmp/ms_tmp/<?php
> echo $image_url; ?>">
> 		 </form>
> 		 </CENTER>
> 		 </BODY>
> 		 </HMTL>
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
