[Mapserver-users] Dyanic Point with Zoom
Eric Bridger
eric at gomoos.org
Wed Nov 5 11:49:03 EST 2003
The map file looks O.K.
You will need to get the other layer, getLayerByName($map, 'prv');
Turn it on and call layer->draw(). The idea is if you use:
$map->prepareImage() you will need to do all the drawing yourself.
You are putting your point at: -73, 46 which does not appear to be in
the middle of your EXTENTS.
-141 - -52 = -89
83 - 41 = 42
so try $lon = -89 and $lat = 42
Eric
On Wed, 2003-11-05 at 21:21, Brian Cunningham wrote:
> When I remove $image=$map->draw(); the point draws but it is not located
> in the center and my other layer does not show up, which does show with
> the $map->draw().
> Is there something wrong with my map file?
> MAP
> NAME TEST
> STATUS ON
> SIZE 600 450
> SYMBOLSET ../etc/symbols.sym
> EXTENT -141.017718 41.679738 -52.619173 83.115060
> UNITS DD
> SHAPEPATH "../data"
> IMAGECOLOR 204 204 204
> FONTSET ../etc/fonts.txt
> WEB
> TEMPLATE MapTemplate.html
> IMAGEPATH "/tmp/ms_tmp/"
> END
> #Tab layers
> LAYER
> NAME prv
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "../data/prv.tab"
> STATUS DEFAULT
> CLASS
> OUTLINECOLOR 0 255 0
> COLOR 204 255 153
> END
> END # Layer
> LAYER
> NAME "point_layer"
> TYPE point
> STATUS on
> CLASS
> NAME 'point_layer'
> STYLE
> COLOR 0 0 255
> SIZE 27
> SYMBOL 'circle'
> END
> END
> END
> END
> -----Original Message-----
> From: Eric Bridger [mailto:eric at gomoos.org]
> Sent: Wednesday, November 05, 2003 10:53 AM
> To: Brian Cunningham
> Cc: Mapserver List
> Subject: Re: [Mapserver-users] Dyanic Point with Zoom
> Brian,
> There is really no need to call $pt_layer->draw(). You already called
> $pt->draw(). Just a guess, but try removing the layer->draw().
> Actually, now that I look at, no need to call $map->draw() either. You
> should just call $map->prepareImage(), $pt->draw(), then
> $image->saveWebImage().
> HTH
> On Wed, 2003-11-05 at 20:18, Brian Cunningham wrote:
> > Hello all-
> > I am stuck and can't figure out what Im doing wrong. I am trying to
> > pass Lat/Long coords which will create a point and zoom to that point.
> > What happens is it zooms to the right coords but the created point
> > object doest show. I figure maybe something is missing or in the
> > wrong order. I have browsed the archive listing and from what I
> > gather it looks right... Below is everything
> > Thanks in advance!
> > Brian
> > #Point Layer
> > LAYER
> > NAME "point_layer"
> > TYPE point
> > STATUS on
> > CLASS
> > NAME 'point_layer'
> > STYLE
> > COLOR 0 0 255
> > SIZE 27
> > SYMBOL 'circle' #(*note: my circle is
> > defined in a symbol set file)
> > END
> > END
> > END
> > <html>
> > <?php
> > dl('php_mapscript.dll');
> > $map_path="../htdocs/";
> > //CREATE INSTANT OF mapOBJECT
> > $map = ms_newMapObj($map_path."test3.map");
> > $image = $map->prepareImage();
> > // CREATE NEW layerObject
> > $pt_layer = ms_newLayerObj($map);
> > $pt_layer = $map->getLayerByName("point_layer");
> > $pt_layer->set("status", 1);
> > //SET NEW POINT OBJECT
> > $pt = ms_newPointObj();
> > //Pass static coords
> > $lon = -73; /*User input*/
> > $lat = 46; /*User input*/
> > //SET POINT OBJECT
> > $pt->setXY($lon, $lat);
> > $pt->draw($map, $pt_layer, $image, 0, "");
> > $pt_layer->set('status', MS_ON);
> > $pt_layer->draw($image);
> > // ZoomPoint - zooooom to point
> > $map->zoompoint(75,$pt,$map->width,$map->height,$map->extent);
> > //Create web image
> > $image_url = $image->saveWebImage(MS_PNG,1,1,0);
> > <html>
> > <HEAD>
> > <TITLE>POINT CREATION</TITLE>
> > </HEAD>
> > <BODY>
> > <CENTER>
> > <form name="form1" method="get">
> > <center><h1>POINT
> > CREATION</h1></center><br>
> > <INPUT TYPE=IMAGE NAME="img"
> SRC="/tmp/ms_tmp/<?php
> > echo $image_url; ?>">
> > </form>
> > </CENTER>
> > </BODY>
> > </HMTL>
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
