[Mapserver-users] Using mapserver to allow a user to create data
- collecting koordinates (points) for a database record
Vladimir Guzmán
vguzman at maintask.com
Fri Nov 7 09:29:20 EST 2003
Lars Forseth wrote:
>Hello!
>I'm doing a study to see wether mapserver/PostGis could be used in the following project:
>North-Troendelag (www.ntfk.no) is within its borders responsible for CRM (Cultural heritage; archaeology). We have a lot of active amateur archaeologists/historians who collect information about warious types of sites. We wish to collect this data into a central database; and allow these people to enter this data through a webpage. Included in the data we want is ofcourse the location of a site; i.e coordinates - points.
>Could mapserver and postgis be used for this. I.e allow a user - after logging in! - to search or select a location - zooming in to it in a suitable scale (1:50000 or 1:5000 maps could be available depending on location within the county) - click on the desired location on the map - after which the coordinates is entered into a database record (i.e postgis). This will happen somwhere in the prosess when the user creates a record of a site. Best would probably be a kind of "guide"!
>Each user should be able to keep a record of the sites he/she has entered; and be able to "map" this - i.e create a hardcopy map showing all the locations they have "mapped". (One rason for this is that farmers in Norway now has to create an "environment plan" for their farms - including all archaeology/CRM sites on the farm).
>Possible/Not possible? Pitfalls?
>(I've talked to our local ESRI rep. And this could be done in ArcIms/Oracle-spatial; but at a price!! (and beside I use Linux at home, so an OS solution is welcome).)
>regards
>larsf
>Lars Forseth
>Archaeologist Nord-Trøndelag FK
>Tlf: 74111270 Mob: 97528143
This is completely possible, using mapserver/mapscript. You can use
postgres, postgis or any other database to store the points.
If you need more specific help, you can contact me, or post a message in
the list.
Best regards,
Vladimir Ilich Guzmán R.
http://www.maintask.com
