[Mapserver-users] raster layer problems with 3.6.5
Dan Harris
coronadh at coronasolutions.com
Sat Nov 8 17:42:01 PST 2003
I have no idea what I'm doing wrong here or if this is a bug. But, I'm
trying to display a raster on my map and I've tried it as 8-bit png,
jpeg, and tiff and it won't render properly.
It is the only layer in the map, so I don't think it's exhausting the
color palette. I've tried reducing to 16 colors and it makes the output
image black instead of gray (is this a clue?). So I can tell that
mapserver is rendering the entire output as the "median" color of the
raster image, but none of the details in the photo actually show up.
I would upgrade to 4.0, but it seems to not mesh with my older GD
libraries in Debian/stable.
Please help!
Here's the relevant layer in my map file:
LAYER
NAME "ORTHO"
DATA "ortho_gray.tiff"
TYPE RASTER
STATUS ON
END
..contents of the .wld file:
16.000000
0.000000
0.000000
-16.000000
-79.91460
32.82132
.. a link to the raster file: http://drivefaster.net/images/ortho_gray.tiff
.. a link to what mapserver generates:
http://drivefaster.net/images/output.png
.. my mapserv -v output:
./mapserv -v
MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
and ldd output for mapserv ( in case it's a library problem? )
-- /mapserver-3.6.5# ldd mapserv
libgd.so.2 => /usr/lib/libgd.so.2 (0x40018000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x4004e000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x4006e000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x400ad000)
libz.so.1 => /usr/lib/libz.so.1 (0x400d8000)
libtiff.so.3 => /usr/lib/libtiff.so.3 (0x400e7000)
libm.so.6 => /lib/libm.so.6 (0x40129000)
libc.so.6 => /lib/libc.so.6 (0x4014a000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40267000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40275000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
Dan Harris
Corona Solutions
720-685-9550
720-870-4068 (direct)
http://www.coronasolutions.com
More information about the MapServer-users
