[Mapserver-users] Postgres 7.2.4 cygwin compilation
Stéphane RIFF
stephane.riff at cerene.fr
Mon Nov 10 02:31:46 EST 2003
What version can send me pls .
Thanks
Tyler Mitchell wrote:
>Stephane, can you follow up with me on Monday. I can see if I can set you
>up with the windows version I've got. I don't know if's ultrasql or not,
>but noooo cygwin. Yes, it includes postgis, that's why I have it. But
>it's an older version.
>mapserver-users-admin at lists.gis.umn.edu wrote on 11/06/2003 12:37:28 AM:
>>The goal is to install postgis....
>>Does the ultraSQL include postgis ????
>>Stéphane RIFF wrote:
>>>Here is the problem :
>>>I can run the ./configure, it's good... but when i run make , i get
>>>this error :
>>> $ make
>>>src/Makefile.global:269: src/Makefile.port: No such file or directory
>>>c:\usr\local\wbin\make.exe:
>>>*** No rule to make target `src/Makefile.port'. Stop.
>>>But there is a Makefile.port in the src directory (it's a link create
>>>by configure).
>>>So i tried to copy the makefile.win in the src directory to replace
>>>the Makefile.port but i ran into others error like windows error:
>>>expr.exe fatal error....
>>>>What kind of error/problem are you running into?
>>>>mapserver-users-admin at lists.gis.umn.edu wrote on 11/05/2003 08:24:51
>AM:
>>>>>I absolutely need a how to for build postgresql 7.2.4 on cygwin with
>>>>>windows 2000
>>>>>I tried every thing i found but nothing work.........
>>>>>PLEASE IF YOU CAN HELP ME, DO IT....
>>>>>thanks
>>>>>_______________________________________________
>>>>>Mapserver-users mailing list
>>>>>Mapserver-users at lists.gis.umn.edu
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
