[Mapserver-users] TrueType fonts problem -- help needed
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Mon Nov 10 09:38:45 EST 2003
there should be no difference between a mapfile for direct-use in MS
and a mapfile used with MS/mapscript. IMHO you should check your php for
the problem first (post the relevant part of the code too, if the
problem continues).
=> Do you execute the drawLabelCache-method (e.g. map->drawLabelCache (
$image ))?
Don't forget the cc to the list!
HTH,
Frieso
>-----Original Message-----
>From: Murat Isik [mailto:muratisik at megatek.com.tr]
>Sent: Monday, November 10, 2003 3:22 PM
>To: Frieso ter Haseborg
>Subject: Re: [Mapserver-users] TrueType fonts problem -- help needed
>Thank you for your reply.
>after my last mail, I have started to play around with labelling and
>achieved good results with mapserver.
>However when I copy the related layer's part from mapserver map file to
>mapscripts mapfile, it first stopped rendering. then I added
>the CLASSITEM
>'ID' line and it started to produce image without labels. Can
>you please
>help me? I am stuck...
>original layer from mapscript mapfile:
>LAYER
> NAME ERENKOY_ORNEKSOKAK_PL_polyline
> GROUP sokaklar
> TYPE line
> DATA ERENKOY_ORNEKSOKAK_PL_polyline
> STATUS ON
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>instead of the above I copied this and labelling did not work:
>LAYER
> TYPE line
> GROUP sokaklar
> STATUS ON
>CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>#LABELCACHE on
>LABELITEM 'ADI'
> CLASS
> NAME 'ADI'
> COLOR 161 02 110
> LABEL
> TYPE truetype
># FORCE true
> FONT arial
> COLOR 0 0 0
> ANGLE AUTO
> BACKGROUNDCOLOR 250 250 250 #WIT
> POSITION AUTO
> SIZE 0
> MINSIZE 2
> SIZE 8
> END
> END
>Should I do something with the php part too?
>Have a nice day:)
>Murat Isik
>----- Original Message -----
>From: "Frieso ter Haseborg" <ter-haseborg at sf-datentechnik.de>
>To: "Murat Isik" <muratisik at megatek.com.tr>
>Cc: <mapserver-users at lists.gis.umn.edu>
>Sent: Monday, November 10, 2003 12:06 PM
>Subject: RE: [Mapserver-users] TrueType fonts problem -- help needed
>> Hi,
>> try to use an absolute path in your "fonts.list".
>> HTH,
>> Frieso ter Haseborg
>> - Software Development -
>> S&F Datentechnik GmbH&Co.KG
>> Reimersstr. 41b
>> 26789 Leer, Germany
>> Sent: Monday, November 10, 2003 10:27 AM
>> To: mapserver-users at lists.gis.umn.edu
>> Subject: [Mapserver-users] TrueType fonts problem -- help needed
>> Hello,
>> I am having a problem with TrueType fonts. This is the error I get:
>> msGetLabelSize(): TrueType Font error. Could not find/open font
>> And this is what I do to get this error:
>> I have these in my mapfile:
>> NAME ERENKOY
>> STATUS ON
>> SIZE 600 600
>> SHAPEPATH "data"
>> IMAGECOLOR 255 255 255
>> FONTSET font.list
>> and
>> LAYER
>> TYPE LINE
>> GROUP sokaklar
>> STATUS ON
>> LABELITEM "ADI"
>> CLASS
>> NAME "ADI"
>> COLOR 161 02 110
>> LABEL
>> TYPE truetype
>> FORCE true
>> FONT arial
>> COLOR 0 0 0
>> POSITION cc
>> SIZE 8
>> END
>> END
>> END
>> This ERENKOY_ORNEKSOKAK_PL_polyline layer's dbf file includes two
>> coloumns, ID and ADI (name). This is a street layer and I am
>trying to
>> get the name of the streets written next to their lines.
>> font.list include:
>> arial arial.ttf
>> arial-bold arialbd.ttf
>> arial-italic ariali.ttf
>> arial-bold-italic arialbi.ttf
>> I have all the related ttf files in the same directory as font.list
>> text, mapfile and the html page calling these fonts. However
>I get the
>> error. May it be that my mapserver is not truetype compiled? I must
>> admit that I installed mapserver and mapscript through rpms so I dont
>> know the trutype situation of my mapserver 3.6. If I can get this
>> labelling to work then I am going to use th same mapfile for
>a mapscript
>> page.
>> Have a nice day.
>> Murat Isik
