[Mapserver-users] MapServer 4 Compile Error on RedHat 7.3
Dirk Geschwandtner
dg at mapmedia.de
Tue Nov 11 09:36:12 EST 2003
Hello Vincent,
thanks for your answer.
At 14:04 11.11.2003, you wrote:
>the missing references should be in the OGR lib which in turn should be
>in GDAL. Some things to consider:
>- when you compiled gdal, did you disable OGR? If so, recompile GDAL
>without the '--without-ogr' switch.
OGR is enabled (at least gdal-config --ogr-enabled says so ...)
>- after (re)compiling gdal, did you run /sbin/ldconfig (as root) to
>update the linker cache, before compiling mapserver?
yes
>- Is your version of GDAL the most recent one? If not, try to update it
>and then recompile mapserver.
I used 1.1.9, now I checked out the cvs version but still nothing changes...
Any other ideas??
