[Mapserver-users] cant label streets in mapscript -- please help
Murat Isik
muratisik at megatek.com.tr
Tue Nov 11 09:59:01 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0068_01C3A875.1B0AD2C0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Good days Mr. Morissette,
I hope it is okey if I ask you a question about mapscript labelling and =
also cc this question to maillist (as you have asked me to do before)
I have tried to label a streets layer in mapserver and succeeded in a =
reasonbale way, names are not perfectly written but I guess it all takes =
some playing around with MINSIZE and/or other values. I will do that.
Before doing that, I tried to do the same thing in my php/mapscript =
which used to run the same mapfile minus the labelling part. I copied =
the mapserver-mapfile's labelled street layer and replaced it into the =
place of the same non-labelled street layer in mapscript-mapfile. This =
is the non-labeled layer of mapscript:
LAYER
NAME ERENKOY_ORNEKSOKAK_PL_polyline
GROUP sokaklar
TYPE line
DATA ERENKOY_ORNEKSOKAK_PL_polyline
STATUS ON
CLASSITEM 'ID'
CLASS
EXPRESSION /./
COLOR 66 34 249
END
END
I removed the above and put this in its place (which worked with =
mapserver):
LAYER
TYPE LINE
GROUP sokaklar
STATUS ON
LABELITEM "ADI"
CLASS
NAME "ADI"
COLOR 161 02 110
LABEL
TYPE truetype
# FORCE true
FONT arial
COLOR 0 0 0
ANGLE AUTO
# BACKGROUNDCOLOR 250 250 250=20
POSITION AUTO
SIZE 0
MINSIZE 2
SIZE 6
END
END
END
ADI is the coloumn in dbf which I am trying to use for labelling. After =
this, mapscript stopped rendering images. Then hopelessly, I added a few =
more lines to mapscript mapfile and it restarted to render maps but with =
no labels. So the layer definition became:
LAYER
TYPE line
GROUP sokaklar
STATUS ON
CLASSITEM 'ID'
CLASS
EXPRESSION /./
COLOR 66 34 249
END
# LABELCACHE OFF
LABELITEM 'ADI'
CLASS
NAME 'ADI'
#EXPRESSION /./
COLOR 161 02 110
LABEL
TYPE truetype
# FORCE true
FONT arial
COLOR 0 0 0
ANGLE AUTO
POSITION AUTO
SIZE 0
MINSIZE 2
SIZE 8
END
END
END
After the advice of Mr. Haseborg from the maillist I added =
$myMap->drawLabelCache($img) line right before =
$img->saveWebImage(GIF,1,1,0) line.
Still no labels were written. This the point I am stuck at. I have read =
a lot of mail archieves but found no results....
Is there anything else to be added to the php code or mapfile? How can I =
get the labelling to work with mapscript?
(It is killing me to be a php-newbei and mapscript-newbei at the same =
time...)
Thanks in advance:)
Have a nice day
Murat Isik
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META content=3D"text/html; charset=3Diso-8859-1" =
http-equiv=3DContent-Type>
<META content=3D"MSHTML 5.00.3700.6699" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Good days Mr. Morissette,</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>I hope it is okey if I ask you a =
question about=20
mapscript labelling and also cc this question to maillist (as you have =
asked me=20
to do before)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>I have tried to label a streets layer =
in mapserver=20
and succeeded in a reasonbale way, names are not perfectly written but I =
guess=20
it all takes some playing around with MINSIZE and/or other values. I =
will do=20
that.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Before doing that, I tried to do the =
same thing in=20
my php/mapscript which used to run the same mapfile minus the labelling =
part. I=20
copied the mapserver-mapfile's labelled street layer and replaced it =
into the=20
is the=20
non-labeled layer of mapscript:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> NAME=20
ERENKOY_ORNEKSOKAK_PL_polyline<BR> GROUP sokaklar<BR> TYPE=20
line<BR> DATA ERENKOY_ORNEKSOKAK_PL_polyline<BR> STATUS =
ON<BR> =20
CLASSITEM 'ID'<BR> =
CLASS<BR> =20
EXPRESSION /./<BR> COLOR 66 34 249<BR> =
END</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>END<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I removed the above and put this in its =
place=20
(which worked with mapserver):</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
ERENKOY_ORNEKSOKAK_PL_polyline<BR> TYPE LINE<BR> GROUP=20
sokaklar<BR> STATUS ON<BR> DATA=20
ERENKOY_ORNEKSOKAK_PL_polyline<BR> LABELITEM "ADI"<BR> =20
CLASS<BR> NAME "ADI"<BR> COLOR 161 =
02=20
110<BR> LABEL<BR> TYPE=20
truetype<BR># FORCE=20
true<BR> FONT=20
arial<BR> COLOR 0 0=20
0<BR> ANGLE=20
AUTO<BR> # BACKGROUNDCOLOR 250 250=20
250 <BR> POSITION=20
AUTO<BR> SIZE=20
0<BR> MINSIZE=20
2<BR> SIZE 6<BR> =
END<BR> =20
END<BR>END<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>ADI is the coloumn in dbf which I am =
trying to use=20
for labelling. After this, mapscript stopped rendering images. Then =
hopelessly,=20
I added a few more lines to mapscript mapfile and it restarted to render =
maps=20
but with no labels. So the layer definition became:</FONT></DIV>
<DIV> </DIV>
ERENKOY_ORNEKSOKAK_PL_polyline<BR> TYPE line<BR> GROUP=20
ERENKOY_ORNEKSOKAK_PL_polyline</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> CLASSITEM =
'ID'<BR> =20
CLASS<BR> =
EXPRESSION=20
=20
END<BR> # LABELCACHE OFF<BR> =
LABELITEM=20
'ADI'<BR> CLASS<BR> NAME=20
'ADI'<BR> #EXPRESSION /./<BR> COLOR 161 02 =
true<BR> FONT=20
0<BR> ANGLE=20
AUTO<BR> SIZE=20
0<BR> MINSIZE=20
2<BR> SIZE 8<BR> END<BR> =
<DIV><FONT face=3DArial size=3D2>After the advice of Mr. Haseborg from =
the maillist=20
I added $myMap->drawLabelCache($img) line right before =20
$img->saveWebImage(GIF,1,1,0) line.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Still no labels were written. This the =
point I am=20
stuck at. I have read a lot of mail archieves but found no=20
results....</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Is there anything else to be added to =
the php code=20
or mapfile? How can I get the labelling to work with =
mapscript?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>(It is killing me to be a php-newbei =
and=20
mapscript-newbei at the same time...)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks in advance:)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice day</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Murat Isik</DIV></FONT></BODY></HTML>
------=_NextPart_000_0068_01C3A875.1B0AD2C0--
