[Mapserver-users] makeref.pl
Lowell Filak lfilak at medinaco.org
Wed Nov 12 12:51:03 PST 2003
Try mapscript::MS_PNG in place of mapscript::MS_PNG=PNG if that doesn't
fix it there is another problem besides syntax.
Lowell
The following message was sent by Rick Buckley <rickb at genaware.com> on
Tue, 11 Nov 2003 14:27:07 +0000.
> Hi,
> Having recently downloaded MapServer,  I am a bit of a novice, so please
> bear with me.
> I have successfully set up the itacsa demo application, ( which is very
> useful ).
> All is fine except that when I try and use the makeref.pl script, I get
> allsorts of errors, many of which I have worked round ( hopefully
> successfully ).
> The error I am now having trouble with is:-
> Can't modify constant item in local at makeref.pl line 47, near
> "mapscript::MS_PNG="
> Line 47 of the file looks like
> #Usage: msSaveImage(img,filename,type,transparent,interlace,quality)
> mapscript::msSaveImage($img, 'reference.png', mapscript::MS_PNG=PNG,
1, 1);
> I suspect I map have the "type" syntax incorrect, however, this is as
> the syntax appears in the doccumentation.
> I have tried various different syntaxs on this line, but cannot get
> through the problem.
> My environemnt of use is:-
> RedHat Linux 8.0
> Could anyone offer any advise please.
> Kind Regards
> Rick Buckley
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
