[Mapserver-users] MapServer 4 Compile Error on RedHat 7.3
Sean Gillies
sgillies at frii.com
Tue Nov 11 08:02:45 PST 2003
On Tuesday, November 11, 2003, at 07:58 AM, Dirk Geschwandtner wrote:
>> You might accidentally have 2 versions of gdal on your system? Try
>> "ldconfig -p | grep gdal". The output should be something like:
>> libgdal.1.1.so (libc6) => /usr/local/lib/libgdal.1.1.so
>> libgdal.so.1 (libc6) => /usr/local/lib/libgdal.so.1
>> libgdal.so (libc6) => /usr/local/lib/libgdal.so
> This is my output:
> Still no change, sorry...
Dirk,
Add --with-ogr=[path to OGR build directory] to your configure. Also,
I see that you will need to build the PROJ.4 library and add --with-proj
to your configure as well.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
More information about the MapServer-users
