[Mapserver-users] Re: Retrieving informations from created swf files...
William A. Bronsema, C.E.T.
bronsema at dmsolutions.ca
Tue Nov 11 12:30:19 EST 2003
I am forwarding this to the mapserver users list. You might get a
faster reply.
BAUD remi wrote:
> Hi,
> I've seen that when mapserver output files in SWF files (Output multiple), this is possible to retrieve informations about that layers: When you "mouse-over" a feature, this last is highlighted, and an Action_Script is made (_root.ElementSelected). Assefa wrote that it's possible to use it to define which layer, shape was clicked and then it's possible to retrieve some attributes.
> If I want to do that, should I create a new .fla document and the use actionscript to load the mapserver's outputed swf files?
> I'm really not sure about how to define this ElementSelected function.
> Don't you have a hint or a little sample about how to do that because it's quite hard to begin..
> Cheers
Applications Developer,
DM Solutions Group Inc.
http://www.dmsolutions.ca
email: bronsema at dmsolutions.ca
Phone: (613) 565-5056 ext.25
Fax : (613) 565-0925
____________________________________
