[Mapserver-users] PROJ 4
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 12 09:44:33 EST 2003
youssef chamoun wrote:
> Hello,
> I am installing Mapserver on an Apache webserver, and I don't have
> access to the httpd.conf to set the PROJ_LIB environment variable, so I
> am getting the error: msProcessProjection(): no system list, errno: 2.
> Is their another solution?
> Can I compile mapserv in order to find directly the espg file?
> I tried setting PROJ_LIB in .htaccess but no luck either.
Youssef,
If you can rebuild PROJ.4, you can hardcode in the location. The
PROJ_LIB macro should be used for this. Ideally at some point I would
like to see some config controls like this and the GDAL_DATA directory
location be settable from in the .map file ... but not today.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
