[Mapserver-users] PROJ 4
    youssef chamoun
    youssefchamoun at hotmail.com
    Wed Nov 12 23:38:09 PST 2003
Hello,
the problem is solved, rebuilding PROJ4 gave me the idea. I rebuilt using
--prefix after putting proj4 folder in the same directory structure as the
web server. And then I called make on mapserver again.
Thank you for your help.
>From: Frank Warmerdam <warmerdam at pobox.com>
>To: youssef chamoun <youssefchamoun at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] PROJ 4
>Date: Wed, 12 Nov 2003 09:44:33 -0500
>youssef chamoun wrote:
>>Hello,
>>I am installing Mapserver on an Apache webserver, and I don't have access
>>to the httpd.conf to set the PROJ_LIB environment variable, so I am
>>getting the error: msProcessProjection(): no system list, errno: 2. Is
>>their another solution?
>>Can I compile mapserv in order to find directly the espg file?
>>I tried setting PROJ_LIB in .htaccess but no luck either.
>Youssef,
>If you can rebuild PROJ.4, you can hardcode in the location.  The
>PROJ_LIB macro should be used for this.  Ideally at some point I would
>like to see some config controls like this and the GDAL_DATA directory
>location be settable from in the .map file ... but not today.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam,
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
_________________________________________________________________
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
More information about the MapServer-users
