[Mapserver-users] ming and mapsever 4.0.1 compile error
Vincent Schut
schut at sarvision.com
Thu Nov 13 06:10:07 EST 2003
Aaron,
Your problem is that mapserver is not linking with the ming library
(there is no '-lming' in the gcc line). What happens if you just
specify '--with-ming' instead of '--with-ming=somedir' (after doing a
make distclean)?
Cheers,
Vincent.
On 2003.11.12 18:08, Aaron D. Hunt wrote:
> When I run make with the following config I get the bellow error
> ./configure --without-tiff --with-proj=/home/mapserver/
> --with-gdal=/home/mapserver/bin/gdal-config
> --with-ogr=/home/mapserver/gdal-1.1.9 --with-jpeg --with-wmsclient
> --with-freetype=/home/mapserver/ --with-gd=/home/mapserver/
> --with-php=/usr/local/src/php-4.3.4/
> --with-curl-config=/home/mapserver/bin/curl-config
> --with-ming=/home/mapserver/
> or --with-ming=/home/mapserver/ming-0.2a
> gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_MING_FLASH
> -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DUSE_OGR -DUSE_GDAL -I/home/mapserver//include
> -I/home/mapserver//include -I/home/mapserver/gdal-1.1.9/ogr/
> ogrsf_frmts
> -I/home/mapserver/gdal-1.1.9/ogr -I/home/mapserver/gdal-1.1.9/ogr/../
> port
> -I/home/mapserver//include -I/home/mapserver//include
> -I/home/mapserver/ shp2img.o -L. -lmap -L/home/mapserver//lib -lgd
> -ljpeg -lfreetype -lpng -lz -ljpeg -lfreetype -lpng -lz
> -L/home/mapserver//lib -lproj -ljpeg -L/home/mapserver//lib
> -lgdal.1.1 -L/home/mapserver//lib -lcurl -L/usr/kerberos/lib -lz
> -lssl -lcrypto -ldl -lssl -lcrypto -lgssapi_krb5 -lkrb5 -lcom_err
> -lk5crypto -lresolv -ldl -lz -lz -lm -lstdc++
> /home/mapserver/gdal-1.1.9/ogr/ogrsf_frmts/ogrsf_frmts.a
> /home/mapserver/gdal-1.1.9/ogr/ogr.a
> /home/mapserver/gdal-1.1.9/ogr/../port/cpl.a -o shp2img
> ./libmap.a(mapswf.o)(.text+0x39): In function `bitmap2shape':
> : undefined reference to `newSWFShape'
> ./libmap.a(mapswf.o)(.text+0x48): In function `bitmap2shape':
> : undefined reference to `newSWFInput_buffer'
> ./libmap.a(mapswf.o)(.text+0x51): In function `bitmap2shape':
> : undefined reference to `newSWFBitmap_fromInput'
> ./libmap.a(mapswf.o)(.text+0x62): In function `bitmap2shape':
> : undefined reference to `SWFShape_addBitmapFill'
> ./libmap.a(mapswf.o)(.text+0x6d): In function `bitmap2shape':
> : undefined reference to `SWFShape_setRightFill'
> ./libmap.a(mapswf.o)(.text+0x81): In function `bitmap2shape':
> : undefined reference to `SWFShape_drawLine'
> ./libmap.a(mapswf.o)(.text+0x95): In function `bitmap2shape':
> ./libmap.a(mapswf.o)(.text+0xab): In function `bitmap2shape':
> ./libmap.a(mapswf.o)(.text+0xc1): In function `bitmap2shape':
> ./libmap.a(mapswf.o)(.text+0x392): In function `BuildButtonFromGD':
> : undefined reference to `newSWFButton'
> ./libmap.a(mapswf.o)(.text+0x3a0): In function `BuildButtonFromGD':
> : undefined reference to `SWFButton_addShape'
> ./libmap.a(mapswf.o)(.text+0x3c3): In function `BuildEllipseShape':
> ./libmap.a(mapswf.o)(.text+0x3f3): In function `BuildEllipseShape':
> : undefined reference to `SWFShape_setLine'
> ./libmap.a(mapswf.o)(.text+0x419): In function `BuildEllipseShape':
> : undefined reference to `SWFShape_addSolidFill'
> ./libmap.a(mapswf.o)(.text+0x425): In function `BuildEllipseShape':
> ./libmap.a(mapswf.o)(.text+0x458): In function `BuildEllipseShape':
> : undefined reference to `SWFShape_movePenTo'
> ./libmap.a(mapswf.o)(.text+0x48d): In function `BuildEllipseShape':
> : undefined reference to `SWFShape_drawCurveTo'
> ./libmap.a(mapswf.o)(.text+0x4b1): In function `BuildEllipseShape':
> ./libmap.a(mapswf.o)(.text+0x4d4): In function `BuildEllipseShape':
> ./libmap.a(mapswf.o)(.text+0x4e7): In function `BuildEllipseShape':
> ./libmap.a(mapswf.o)(.text+0x561): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x56d): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x59d): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x5e0): In function `BuildEllipseButton':
> : undefined reference to `compileSWFActionCode'
> ./libmap.a(mapswf.o)(.text+0x5e9): In function `BuildEllipseButton':
> : undefined reference to `SWFButton_addAction'
> ./libmap.a(mapswf.o)(.text+0x615): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x61e): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x64a): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x653): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x67f): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x688): In function `BuildEllipseButton':
> ./libmap.a(mapswf.o)(.text+0x6d8): In function `BuildPolygonShape':
> ./libmap.a(mapswf.o)(.text+0x700): In function `BuildPolygonShape':
> ./libmap.a(mapswf.o)(.text+0x726): In function `BuildPolygonShape':
> ./libmap.a(mapswf.o)(.text+0x732): In function `BuildPolygonShape':
> ./libmap.a(mapswf.o)(.text+0x782): In function `BuildPolygonShape':
> : undefined reference to `SWFShape_drawLineTo'
> ./libmap.a(mapswf.o)(.text+0x7cd): In function `BuildPolygonShape':
> ./libmap.a(mapswf.o)(.text+0x7fc): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x829): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x849): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x853): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x873): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x893): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x8bb): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x8ea): In function `BuildShape':
> ./libmap.a(mapswf.o)(.text+0x908): In function `BuildShapeLine':
> ./libmap.a(mapswf.o)(.text+0x939): In function `BuildShapeLine':
> ./libmap.a(mapswf.o)(.text+0x951): In function `BuildShapeLine':
> ./libmap.a(mapswf.o)(.text+0x989): In function `BuildShapeLine':
> ./libmap.a(mapswf.o)(.text+0x9b8): In function `BuildShapeLine':
> ./libmap.a(mapswf.o)(.text+0x9d4): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0x9f5): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xa23): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xa66): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xa6f): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xa9b): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xaa4): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xad0): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xad9): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xb05): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xb0e): In function `BuildButtonPolygon':
> ./libmap.a(mapswf.o)(.text+0xb4c): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xb74): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xb97): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xbda): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xbe3): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xc0f): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xc18): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xc44): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xc4d): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xc79): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xc82): In function `BuildButtonLine':
> ./libmap.a(mapswf.o)(.text+0xd80): In function `msImageCreateSWF':
> : undefined reference to `newSWFMovie'
> ./libmap.a(mapswf.o)(.text+0xd9c): In function `msImageCreateSWF':
> : undefined reference to `SWFMovie_setDimension'
> ./libmap.a(mapswf.o)(.text+0xef2): In function
> `msImageStartLayerSWF':
> ./libmap.a(mapswf.o)(.text+0xf25): In function
> ./libmap.a(mapswf.o)(.text+0xf9b): In function
> ./libmap.a(mapswf.o)(.text+0xfae): In function
> : undefined reference to `SWFMovie_add'
> ./libmap.a(mapswf.o)(.text+0xfd1): In function
> ./libmap.a(mapswf.o)(.text+0xfe6): In function
> ./libmap.a(mapswf.o)(.text+0x1019): In function
> ./libmap.a(mapswf.o)(.text+0x102d): In function
> ./libmap.a(mapswf.o)(.text+0x1057): In function
> ./libmap.a(mapswf.o)(.text+0x106f): In function
> ./libmap.a(mapswf.o)(.text+0x11fa): In function
> `msDrawStartShapeSWF':
> ./libmap.a(mapswf.o)(.text+0x1214): In function
> ./libmap.a(mapswf.o)(.text+0x1263): In function
> ./libmap.a(mapswf.o)(.text+0x127d): In function
> ./libmap.a(mapswf.o)(.text+0x1374): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x137d): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x13a5): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x13ae): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x13d6): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x13df): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x140b): In function `AddMouseActions':
> ./libmap.a(mapswf.o)(.text+0x180c): In function
> `msDrawMarkerSymbolSWF':
> ./libmap.a(mapswf.o)(.text+0x1b50): In function
> ./libmap.a(mapswf.o)(.text+0x1b81): In function
> : undefined reference to `SWFDisplayItem_moveTo'
> ./libmap.a(mapswf.o)(.text+0x1d6b): In function
> ./libmap.a(mapswf.o)(.text+0x1d82): In function
> ./libmap.a(mapswf.o)(.text+0x2380): In function `DrawShapePolyline':
> ./libmap.a(mapswf.o)(.text+0x23a4): In function `DrawShapePolyline':
> ./libmap.a(mapswf.o)(.text+0x23dc): In function `DrawShapePolyline':
> ./libmap.a(mapswf.o)(.text+0x241e): In function `DrawShapePolyline':
> ./libmap.a(mapswf.o)(.text+0x246c): In function
> `DrawButtonFilledPolygon':
> ./libmap.a(mapswf.o)(.text+0x248a): In function
> ./libmap.a(mapswf.o)(.text+0x24b1): In function
> ./libmap.a(mapswf.o)(.text+0x2504): In function `DrawButtonPolyline':
> ./libmap.a(mapswf.o)(.text+0x251b): In function `DrawButtonPolyline':
> ./libmap.a(mapswf.o)(.text+0x2535): In function `DrawButtonPolyline':
> ./libmap.a(mapswf.o)(.text+0x25b4): In function `DrawText':
> : undefined reference to `loadSWFFontFromFile'
> ./libmap.a(mapswf.o)(.text+0x25ca): In function `DrawText':
> : undefined reference to `newSWFText'
> ./libmap.a(mapswf.o)(.text+0x25d6): In function `DrawText':
> : undefined reference to `SWFText_setFont'
> ./libmap.a(mapswf.o)(.text+0x25ea): In function `DrawText':
> : undefined reference to `SWFText_moveTo'
> ./libmap.a(mapswf.o)(.text+0x2606): In function `DrawText':
> : undefined reference to `SWFText_setColor'
> ./libmap.a(mapswf.o)(.text+0x2619): In function `DrawText':
> : undefined reference to `SWFText_setHeight'
> ./libmap.a(mapswf.o)(.text+0x2627): In function `DrawText':
> : undefined reference to `SWFText_addString'
> ./libmap.a(mapswf.o)(.text+0x2785): In function
> `msDrawLineSymbolSWF':
> ./libmap.a(mapswf.o)(.text+0x29fa): In function
> `msDrawShadeSymbolSWF':
> ./libmap.a(mapswf.o)(.text+0x2c7c): In function `draw_textSWF':
> ./libmap.a(mapswf.o)(.text+0x2c98): In function `draw_textSWF':
> ./libmap.a(mapswf.o)(.text+0x2cb6): In function `draw_textSWF':
> : undefined reference to `SWFDisplayItem_rotate'
> ./libmap.a(mapswf.o)(.text+0x2e02): In function `msGetLabelSizeSWF':
> ./libmap.a(mapswf.o)(.text+0x2e22): In function `msGetLabelSizeSWF':
> ./libmap.a(mapswf.o)(.text+0x2e33): In function `msGetLabelSizeSWF':
> ./libmap.a(mapswf.o)(.text+0x2e3e): In function `msGetLabelSizeSWF':
> : undefined reference to `SWFText_getStringWidth'
> ./libmap.a(mapswf.o)(.text+0x3e74): In function
> `msDrawLabelCacheSWF':
> ./libmap.a(mapswf.o)(.text+0x403e): In function `msDrawWMSLayerSWF':
> ./libmap.a(mapswf.o)(.text+0x417e): In function
> `msDrawRasterLayerSWF':
> ./libmap.a(mapswf.o)(.text+0x425a): In function `msSaveImageSWF':
> : undefined reference to `fileOutputMethod'
> ./libmap.a(mapswf.o)(.text+0x4260): In function `msSaveImageSWF':
> : undefined reference to `SWFMovie_output'
> ./libmap.a(mapswf.o)(.text+0x42b3): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x42c4): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x42f0): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x4301): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x432e): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x433f): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x436c): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x437d): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x43dd): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x43ee): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x441b): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x442c): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x4453): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x4464): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x448b): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x449c): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x4637): In function `msSaveImageSWF':
> : undefined reference to `SWFMovie_setBackground'
> ./libmap.a(mapswf.o)(.text+0x4664): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x466a): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x46c8): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x46da): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x471c): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x4722): In function `msSaveImageSWF':
> ./libmap.a(mapswf.o)(.text+0x479e): In function `msFreeImageSWF':
> : undefined reference to `destroySWFMovie'
> ./libmap.a(mapswf.o)(.text+0x47d6): In function `msFreeImageSWF':
> ./libmap.a(mapswf.o)(.text+0x4949): In function
> `msDrawVectorLayerAsRasterSWF':
> ./libmap.a(mapswf.o)(.text+0x1420): In function `AddMouseActions':
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> Aaron D. Hunt
> Technical Manager
> ZedX Inc.
> Voice: 814-357-8490
> Fax: 814-357-8499
