[Mapserver-users] UTM and 10TM
Doug Cates
doug at moximedia.com
Thu Nov 13 15:34:00 EST 2003
Chris,
Try:
PROJECTION
# Alberta 10TM
"proj=tmerc"
"ellps=GRS80"
"lon_0=-115.0"
"lat_0=0.0"
"k=0.9992"
"x_0=500000.0"
END
Doug
On Thu, 2003-11-13 at 12:01, Chris Storozuk wrote:
> Thanks Paul,
> Do you know if there is a definition to 10TM for my Alberta input layers? I
> have not been able to find one (in the Proj folder) - do I need to generate
> it myself?
> Chris
> ----- Original Message -----
> From: "Paul Ramsey" <pramsey at refractions.net>
> To: "Chris Storozuk" <cstorozuk at shaw.ca>
> Cc: "mapserver-users" <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, November 13, 2003 1:47 PM
> Subject: Re: [Mapserver-users] UTM and 10TM
> > > Dear Western Canada users,
> > > My application spans 2 provinces, Alberta and BC. Our data for Alberta
> > > is in 10TM, which is a custom projection to cover all of the province,
> > > and for BC it is in UTM.
> > > When a user looks at a border area, how can I display data from both
> > > datasets at the same time, or can I? Would this require using projection
> > > items, and then trying to project one to the other?
> > Yes, you will declare a projection under the MAP object, and that will
> > be the output projection. THen you'll define a projection for each
> > layer, and those will be the input projections of the data being read.
> > Mapserver will convert the incoming data to the output projection, then
> > render the output image, so the data will end up nicely integrated.
> > Paul
> > > Thanks,
> > > Chris Storozuk
> > __
> > | Paul Ramsey
> > | Refractions Research
> > | Email: pramsey at refractions.net
> > | Phone: (250) 885-0632
> > \_
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
