[Mapserver-users] UTM and 10TM
Chris Storozuk
cstorozuk at shaw.ca
Thu Nov 13 15:01:44 EST 2003
Thanks Paul,
Do you know if there is a definition to 10TM for my Alberta input layers? I
have not been able to find one (in the Proj folder) - do I need to generate
it myself?
Chris
----- Original Message -----
To: "Chris Storozuk" <cstorozuk at shaw.ca>
Cc: "mapserver-users" <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, November 13, 2003 1:47 PM
Subject: Re: [Mapserver-users] UTM and 10TM
> Chris Storozuk wrote:
> > Dear Western Canada users,
> > My application spans 2 provinces, Alberta and BC. Our data for Alberta
> > is in 10TM, which is a custom projection to cover all of the province,
> > and for BC it is in UTM.
> > When a user looks at a border area, how can I display data from both
> > datasets at the same time, or can I? Would this require using projection
> > items, and then trying to project one to the other?
> Yes, you will declare a projection under the MAP object, and that will
> be the output projection. THen you'll define a projection for each
> layer, and those will be the input projections of the data being read.
> Mapserver will convert the incoming data to the output projection, then
> render the output image, so the data will end up nicely integrated.
> Paul
> > Thanks,
> > Chris Storozuk
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
