[Mapserver-users] Positioning of labels
    Johan Antonsson
    johan at antonsson.com
    Sun Nov 16 05:52:18 PST 2003
Hi all,
In my map sets there is information about label positions in the
annotation layer attribute table. The positioning system is about the
same as in the POSITION CLASS object parameter except that it uses
numbers instead of named positions:
POSITION parameter
ul uc ur
cl cc cr
ll lc lr
Position information in my .dbf file
7 8 9
4 5 6
1 2 3
I don't like to use the POSITION parameter since every label has its own
position relative to its point. What I'm looking for is a parameter in
the LAYER object e.g. called LABELPOSITIONITEM that would refer to the
position attribute table column. Is there such a feature in MapServer or
do I have to be content with POSITION=auto in the CLASS object?
TIA
/Johan
Johan Antonsson
More information about the MapServer-users
