[Mapserver-users] Creating dynamic shapefiles with Python Mapscript
    Michael Schulz
    mschulz at webgis.de
    Tue Nov 18 03:49:40 PST 2003
Hi Bjoern,
if you only want to create a point data shapefile, you don't need to
create a shapeObj/lineObj.
You could just do:
newshpfile = mapscript.shapefileObj(shpName,mapscript.MS_SHAPEFILE_POINT)
# iterate over your result set
for l in r[1]:
  p = mapscript.pointObj()
  p.x = l[0]
  p.y = l[1]
  newshpfile.addPoint(p)
If you want to create a line shapefile:
newlshpfile = mapscript.shapefileObj(shpName,mapscript.MS_SHAPEFILE_ARC)
lineobjekt = mapscript.lineObj()
shpobjekt = mapscript.shapeObj(mapscript.MS_SHAPE_LINE)
for l in r[1]:
  p.x = l[0]
  p.y = l[1]
  lineobjekt.add(p)
shpobjekt.add(lineobjekt)
newlshpfile.add(shpobjekt)
For a queryable shapefile you still need the corresponding dbf-file. I suggest using the python binding for dbflib. Don't go for the mapscript dbf functions.
HTH, Michael
Michael Schulz                                in medias res
Dipl.-Geologe                              Gesellschaft für
                                Informationstechnologie mbH
                                     In den Weihermatten 66
                                             79108 Freiburg
                                     0761 55695-95 (Fax 96)
mschulz at webgis.de              www.webgis.de/www.zopecms.de
Bjoern Platzen schrieb:
>        myShape = mapscript.shapefileObj(shpName,
>        myLayer = self.mymap.getLayerByName(layer)
>	#open the sql-file
>        query = open('sql/'+queryfile+'.sql', 'r').read()
>		#querying the database
>        r = self.Conn.get_result(query)
>        if r[0]>0:#r=(numrecords,[[k1,k2],[k3,k4],[k5,k6],...]
>	    #define a new shape object
>            newShape = mapscript.shapeObj(mapscript.MS_SHAPE_POINT)
>            for l in r[1]:
>		#define a lineobject
>                part = mapscript.lineObj()
>                #make the pointobject
>		newPoint = mapscript.pointObj()
>                newPoint.x = l[0]
>                newPoint.y = l[1]
>		#add the point to the line
>                part.add(newPoint)
>		#add the line to the shapeobject
>                newShape.add(part)
>            #print myShape
>	    #add the shapeobject to the shapefileobject
>            myShape.add(newShape)
>        myLayer.status = mapscript.MS_ON
>        myShape=None
>Now I get the following Error:
>Traceback (innermost last):
> File "/usr/local/httpd/htdocs/bauinfo/mapwindow.py", line 32, in ?
>theMap = map.Map(mapfile, 'png', webargs=dct, Conn=dbConn,
>dynamic=dynamic_layer)
>File "/usr/local/httpd/htdocs/bauinfo/ms/map.py", line 150, in __init__
>self.processMap()
>File "/usr/local/httpd/htdocs/bauinfo/ms/map.py", line 237, in
>processMap self._makeDynamicLayer(lay[0], lay[1])
>File "/usr/local/httpd/htdocs/bauinfo/ms/map.py", line 400, in
>_makeDynamicLayer myShape.add(newShape)
>File "/usr/lib/python2.2/site-packages/mapscript.py", line 336, in add
>def add(*args): return apply(_mapscript.shapefileObj_add,args)
>TypeError: Type error. Expected _p_shapefileObj
>print myShape returns <C shapefileObj instance at None>
>What am I missing?? What goes wrong here??
>Any help would be great!
>Bye,
>Bjoern
More information about the MapServer-users
