[Mapserver-users] Creating dynamic shapefiles with Python Mapscript
Bjoern Platzen
bplatzen at sosnetz.de
Tue Nov 18 09:01:09 EST 2003
Hi Michael.
Thanks a lot! Now it works...
... but the Error was caused by this:
myShape=mapscript.shapefileObj(shpName, mapscript.MS_SHAPE_POINT)
It took me a minute to recognize the difference between your suggestion
on how to create the shapefileObj and my function... 8~)
> if you only want to create a point data shapefile, you don't need to
> create a shapeObj/lineObj.
> You could just do:
> newshpfile =
> mapscript.shapefileObj(shpName,mapscript.MS_SHAPEFILE_POINT) #
> iterate over your result set
> for l in r[1]:
> p = mapscript.pointObj()
> p.x = l[0]
> p.y = l[1]
> newshpfile.addPoint(p)
But I think, I've got to build the lineObj and the shapeObj as well, to
add them to the layer. If I only build the shapefile, my Features won't
be visible on the map. Or is there a way to add the shapefileObject to
the layer? (myLayer.data = myShapefileName didn't work).
Bye,
Bjoern.
small office solutions
info at sosnetz.de - http://www.sosnetz.de
