[Mapserver-users] Creating dynamic shapefiles with Python Mapscript
Michael Schulz
mschulz at webgis.de
Tue Nov 18 11:11:14 EST 2003
Hi Bjoern,
> Or is there a way to add the shapefileObject to
>the layer? (myLayer.data = myShapefileName didn't work).
Well, actually that should work, but not with the shapefileobj, the
filename of you newly created shapefile is enough (you probably have to
"close" the new shapefile with shapefileObj=None before). Otherwise if
you only want to add some features to the layerobj, you can use
layerobj.addFeature, that only takes a shapeobj, so you don't need a
shapefileobj.
Cheers, Michael
