[Mapserver-users] Creating dynamic shapefiles with Python Mapscript
Björn Platzen
bplatzen at sosnetz.de
Tue Nov 18 11:59:16 EST 2003
Hi Michael,
now I decided to walk the way, Eric suggested.
Nevertheless, thanks for helping! I saw that I need that way in another
project, where the Features change maybe once a year. There, I think,
it will have a greater performance to write a new shapefile if
something changes and then use the shapefile as layer data.
> > Or is there a way to add the shapefileObject to
> >the layer? (myLayer.data = myShapefileName didn't work).
> Well, actually that should work, but not with the shapefileobj, the
> filename of you newly created shapefile is enough (you probably have
> to "close" the new shapefile with shapefileObj=None before).
> Otherwise if you only want to add some features to the layerobj, you
> can use layerobj.addFeature, that only takes a shapeobj, so you don't
> need a shapefileobj.
You're right! that should work... The problem was, that myShapefileName
contained the shapepath, the shapename and the appendix '.shp'...
Bye,
Bjoern.
small office solutions
info at sosnetz.de - http://www.sosnetz.de
