[Mapserver-users] initialisation Proj
Yvain Ballini
yvain.ballini at seat.it
Tue Nov 18 07:06:33 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0065_01C3ADD4.CA499DC0
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
charset="iso-8859-1"
Hi List,
I'm using the proj.lib under Mapserver and would like to know how to =
initialze the parameters of the projection I want to use. For the test I =
use a mapfile where I define the projection like that (see under). The =
problem is that when I change the parameter proj, it changes nothing on =
my map (which isn't good). It's as if there would an initialization by =
default...does someone know how to change these parameters?
I'm using the proj.lib from proj-4.4.7, compiled with VC7.
NAME DEV
STATUS ON
SIZE 430 380
EXTENT 7.680 45.06 7.685 45.06
DEBUG TRUE
SHAPEPATH "data"
IMAGECOLOR 189 198 206
PROJECTION
proj=3Dutm
ellps=3DWGS84
zone=3D15
north
=20
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
Thnk you very much.
Yvain.
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi List,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I'm using the proj.lib under Mapserver =
and would=20
like to know how to initialze the parameters of the projection I want to =
use.=20
For the test I use a mapfile where I define the projection like that =
(see=20
under). The problem is that when I change the parameter proj, it changes =
nothing=20
on my map (which isn't good). It's as if there would an initialization =
by=20
default...does someone know how to change these parameters?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'm using the proj.lib from proj-4.4.7, =
compiled=20
with VC7.</FONT></DIV>
<DIV>
<DIV><FONT size=3D2>
<P>NAME DEV</P>
<P>STATUS ON</P>
<P>SIZE 430 380</P>
<P>EXTENT 7.680 45.06 7.685 45.06</P>
<P>DEBUG TRUE</P>
<P>SHAPEPATH "data"</P>
<P>IMAGECOLOR 189 198 206</P>
<P>PROJECTION</P>
<P>proj=3Dutm</P>
<P>ellps=3DWGS84</P>
<P>zone=3D15</P>
<P>north</P>
<P> </P>
<P>END</P>
<P>OUTPUTFORMAT</P>
<P>NAME png</P>
<P>DRIVER "GD/PNG"</P>
<P>MIMETYPE "image/png"</P>
<P>IMAGEMODE RGB</P>
<P>EXTENSION "png"</P>
<P>END</P>
<P> </P>
<P><FONT face=3DArial>Thnk you very much.</FONT></P>
<P><FONT face=3DArial>Yvain.</FONT></P></FONT></DIV></DIV></BODY></HTML>
------=_NextPart_000_0065_01C3ADD4.CA499DC0--
