[Mapserver-users] initialisation Proj
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Nov 18 05:24:22 PST 2003
Yvain Ballini wrote:
> Hi List,
> I'm using the proj.lib under Mapserver and would like to know how to
> initialze the parameters of the projection I want to use. For the test I
> use a mapfile where I define the projection like that (see under). The
> problem is that when I change the parameter proj, it changes nothing on
> my map (which isn't good). It's as if there would an initialization by
> default...does someone know how to change these parameters?
> I'm using the proj.lib from proj-4.4.7, compiled with VC7.
Yvain,
You will also need to show the projection definition you use for your
layer(s) as well for us to diagnose what may be the problem.  The reprojection
is only done by MapServer when it knows the layer data is in a different
projection than the map projection definition.
Best regards,
More information about the MapServer-users
