[Mapserver-users] Setting the classindex of a shapeObj()
has no effect
Eric Bridger
eric at gomoos.org
Wed Nov 19 08:09:55 EST 2003
Bjoern,
Since I use the same method for drawing points I've run into the same issue. I think the comments in my Wiki example mention this. I never figured out exactly why this is so. Perhaps a layers features are drawn without respect to any Class attributes.
The solution I use is to call $class = $layer->getClass($class_index); # class_index is based on some category
Then set the attrbutes, e.g. $class->{symbol} = $symbol_index;
$class->{size} = 20;
$class->{color} = .... etc.
Finally $pointDraw($map, $layer, $point ...)
in ADDITION to calling $layer->addFeature($shape) which makes the points queryable.
This seems like something of a hack, i.e. drawing all the points twice.
I don't call $layer->draw()
In your case you may not need to set the class attributes. Perhaps just calling
$layer->getClass(0) or getClass(1) prior to $point->draw() will be enough.
Eric
At 12:36 AM 11/19/2003 +0100, Bjoern Platzen wrote:
>Hi folks,
>I'm still messing around with PythonMapScript...
>With a lot of help from the list, I am now able to create queryable
>Features for a layer. Now I want to show my points with different
>symbols. In my database-table, Ive got a field for a category. If the
>category-field contains '1', the point should be drawn with the CLASS
>0, otherwise with CLASS 1.
>Here's the layer-definition in the mapfile:
>LAYER
> NAME 'baustellen'
> TYPE POINT
> STATUS on
> CLASS
> Symbol 'bau'
> END#class
> CLASS
> Symbol 'db'
> END#class
> TEMPLATE 'rahmen2.html'
> TOLERANCE 50
>END#LAYER
>END # Map File
>Here's the code-snippet, that produces the points:
>for l in r[1]:
> #r[1] is the resultset[[pointx,pointy,date1,date2,category],[..],..]
> newPoint = mapscript.pointObj()
> newPoint.x = l[0]
> newPoint.y = l[1]
> newLine = mapscript.lineObj()
> newLine.add(newPoint)
> newShape = mapscript.shapeObj(mapscript.MS_SHAPE_POINT)
> newShape.add(newLine)
> newShape.index=l[6]
> if l[4]=='1':#l[4] contains the category
> newShape.classindex = 0
> else:
> newShape.classindex = 1
> myLayer.addFeature(newShape)
>All features are displayed with the symbol defined in CLASS 0.
>I thought classindex would be an attribute of the shapeObj() that is
>read- and writeable.
>What will I have to do to display my Points with different
>symbols/classes??
>Thanks in advance for any help!
>Bye,
>Bjoern
>small office solutions
>info at sosnetz.de - http://www.sosnetz.de
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
