[Mapserver-users] ld32: ERROR 33
Andre Seifert
ASeifert at schwerin.de
Thu Nov 20 06:50:18 EST 2003
Hi folks,
what means
ld32: ERROR 33
Mapserver 4.0.1
IRIX 6.5
gcc 3.3
echo "# configure ###########################################################"
./configure \
--with-tiff=/usr/local\
--with-png=/usr/local\
--with-jpeg=/usr/local\
--with-gdal=/usr/local/bin/gdal-config\
--with-gd=/usr/local
echo "# make ################################################################"
make
creating cache ./config.cache
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++ ) works... yes
checking whether the C++ compiler (c++ ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking for ranlib... :
checking for flex... flex
checking for yywrap in -lfl... no
checking for bison... bison -y
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for exp in -lm... yes
checking for __gxx_personality_v0 in -lstdc++... yes
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking whether we should include JPEG support...
using libjpeg from system -L/usr/local/lib -ljpeg
checking where FreeType 2.x is installed...
checking for FT_Init_FreeType in -lfreetype... no
freetype-config or libfreetype cannot be found, possibly needed for GD
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs.
checking where PNG is installed...
using libpng from -L/usr/local/lib -lpng
checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... yes
using libXpm from system libs.
checking where libiconv is installed...
checking for libiconv_open in -liconv... no
libiconv library cannot be found, possibly needed for GD
checking for GD 2.0.12 or higher...
checking for gdImageSetAntiAliased in -lgd... yes
using libgd 2.0.12 (or higher) from -L/usr/local/lib -lgd -L/usr/local/lib -ljpeg -L/usr/local/lib -lpng -lz -lXpm -lX11
checking for gdImageGif in -lc... no
checking for gdImagePng in -lc... yes
checking for gdImageJpeg in -lc... yes
checking for gdImageWBMP in -lc... yes
checking for gdImageStringFT in -lc... yes
checking for gdImageGifPtr in -lc... no
using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT) from /usr/local.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
libpdf not found... PDF support not included.
checking whether we should include TIFF support...
using libtiff from -L/usr/local/lib -ltiff.
checking whether we should include EPPL7 support...
including EPPL7 support.
checking whether we should include PROJ.4 support...
PROJ.4 support not requested.
checking whether we should include thread safe support...
thread safe support disabled.
checking whether we should include ESRI SDE support...
ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
MPATROL support not requested.
checking whether we should include OGR support...
OGR support not requested.
checking if GDAL support requested... yes, user supplied gdal-config (/usr/local/bin/gdal-config)
checking if PostGIS support requested... no
checking if MyGIS support requested... no
checking if OracleSpatial support requested... no
checking if MING/Flash support requested... no
checking whether we should include WMS Server support...
OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
checking whether we should include WFS Server support...
OGC WFS Server support not requested.
checking whether we should include WMS Client Connections support...
OGC WMS Client Connections not enabled (PROJ.4 and libcurl required).
checking whether we should include WFS Client Connections support...
OGC WFS Client Connections not enabled (PROJ.4, libcurl and OGR required).
checking for curl-config
checking HTTPD server (Apache) version
checking for httpd... no
'httpd' not found, skipping Apache version detection. You may want to use --with-httpd=/path/to/httpd
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
PHP/MapScript module not configured.
updating cache ./config.cache
creating ./config.status
creating Makefile
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maptemplate.c -o maptemplate.o
maptemplate.c: In function `generateLegendTemplate':
maptemplate.c:1350: Warnung: long int format, different type arg (arg 3)
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapbits.c -o mapbits.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maphash.c -o maphash.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapshape.c -o mapshape.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapxbase.c -o mapxbase.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapparser.c -o mapparser.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maplexer.c -o maplexer.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maptree.c -o maptree.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapsearch.c -o mapsearch.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapstring.c -o mapstring.o
mapstring.c: In function `msEncodeUrl':
mapstring.c:408: Warnung: subscript has type `char'
mapstring.c:419: Warnung: subscript has type `char'
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapsymbol.c -o mapsymbol.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapfile.c -o mapfile.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maplegend.c -o maplegend.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maputil.c -o maputil.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapscale.c -o mapscale.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapquery.c -o mapquery.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maplabel.c -o maplabel.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maperror.c -o maperror.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapprimitive.c -o mapprimitive.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapproject.c -o mapproject.o
mapproject.c: In function `msGetEPSGProj':
mapproject.c:429: Warnung: return makes pointer from integer without a cast
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapraster.c -o mapraster.o
mapraster.c: In function `readGEOTiff':
mapraster.c:304: Warnung: dereferencing type-punned pointer will break strict-aliasing rules
mapraster.c:308: Warnung: dereferencing type-punned pointer will break strict-aliasing rules
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapsde.c -o mapsde.o
c++ -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapogr.cpp -o mapogr.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mappostgis.c -o mappostgis.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapmygis.c -o mapmygis.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maplayer.c -o maplayer.o
maplayer.c: In function `msLayerWhichItemsNew':
maplayer.c:629: Warnung: unused variable `i'
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapresample.c -o mapresample.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapwms.c -o mapwms.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapwmslayer.c -o mapwmslayer.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maporaclespatial.c -o maporaclespatial.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapgml.c -o mapgml.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapprojhack.c -o mapprojhack.o
mapprojhack.c:71: Warnung: `ConvertProjUnitStringToMS' defined but not used
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapthread.c -o mapthread.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapdraw.c -o mapdraw.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapgd.c -o mapgd.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapoutput.c -o mapoutput.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapgdal.c -o mapgdal.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapswf.c -o mapswf.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapimagemap.c -o mapimagemap.o
mapimagemap.c:59: Warnung: `searchImageCache' defined but not used
mapimagemap.c:89: Warnung: `addImageCache' defined but not used
mapimagemap.c:333: Warnung: `imageOffsetPolyline' defined but not used
mapimagemap.c:364: Warnung: `imagePolyline' defined but not used
mapimagemap.c:1392: Warnung: `billboardIM' defined but not used
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapows.c -o mapows.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapwfs.c -o mapwfs.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapwfslayer.c -o mapwfslayer.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapcontext.c -o mapcontext.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include maphttp.c -o maphttp.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapdrawgdal.c -o mapdrawgdal.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mappdf.c -o mappdf.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapjoin.c -o mapjoin.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapgraticule.c -o mapgraticule.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include mapcopy.c -o mapcopy.o
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include epplib.c -o epplib.o
ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o mapmygis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o mapdraw.o mapgd.o mapoutput.o mapgdal.o mapswf.o mapimagemap.o mapows.o mapwfs.o mapwfslayer.o mapcontext.o maphttp.o mapdrawgdal.o mappdf.o mapjoin.o mapgraticule.o mapcopy.o epplib.o
: libmap.a
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include shp2img.c -o shp2img.o
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/local/include -I/usr/local/include -I/usr/local/include -I/usr/local/include shp2img.o -L. -lmap -L/usr/local/lib -lgd -L/usr/local/lib -ljpeg -L/usr/local/lib -lpng -lz -lXpm -lX11 -L/usr/local/lib -ltiff -L/usr/local/lib -ljpeg -L/usr/local/lib -lpng -lz -lXpm -lX11 -L/usr/local/lib -ljpeg /usr/local/lib/ogrsf_frmts.a /usr/local/lib/gdal.a /usr/local/lib/ogr.a /usr/local/lib/gdal.a /usr/local/lib/cpl.a -L/usr/local -L/usr/local/lib -ljpeg -L/usr/local/lib -ltiff -L/usr/local -L/usr/local/lib -lpng -L/usr/local -L/usr/local -lz -lm -ldl -lm -lm -lstdc++ -o shp2img
ld32: WARNING 84 : /usr/local/lib/libpng.a is not used for resolving any symbol.
ld32: WARNING 84 : /usr/local/lib/libz.a is not used for resolving any symbol.
ld32: WARNING 84 : /usr/local/lib/ogrsf_frmts.a is not used for resolving any symbol.
ld32: WARNING 84 : /usr/local/lib/gdal.a is not used for resolving any symbol.
ld32: WARNING 84 : /usr/local/lib/cpl.a is not used for resolving any symbol.
ld32: WARNING 84 : /usr/lib32/libdl.so is not used for resolving any symbol.
ld32: ERROR 33 : Unresolved text symbol "OGRSpatialReference::OGRSpatialReference[in-charge](char const*)" -- 1st referenced by ./libmap.a(mapogr.o).
Use linker option -v to see when and which objects, archives and dsos are loaded.
ld32: ERROR 33 : Unresolved text symbol "OGRSpatialReference::importFromWkt(char**)" -- 1st referenced by ./libmap.a(mapogr.o).
ld32: ERROR 33 : Unresolved text symbol "OGRSpatialReference::~OGRSpatialReference [in-charge]()" -- 1st referenced by ./libmap.a(mapogr.o).
ld32: ERROR 33 : Unresolved text symbol "operator delete(void *)" -- 1st referenced by /usr/local/lib/gdal.a(ogr_srs_proj4.o).
ld32: ERROR 33 : Unresolved text symbol "operator new(unsigned int)" -- 1st referenced by /usr/local/lib/gdal.a(gdalrasterband.o).
ld32: ERROR 33 : Unresolved text symbol "__vec_new_eh2" -- 1st referenced by /usr/local/lib/gdal.a(ddfmodule.o).
ld32: ERROR 33 : Unresolved text symbol "__vec_delete2" -- 1st referenced by /usr/local/lib/gdal.a(ddfmodule.o).
ld32: ERROR 33 : Unresolved text symbol "__nwa(unsigned int)" -- 1st referenced by /usr/local/lib/gdal.a(ddfrecord.o).
ld32: ERROR 33 : Unresolved text symbol "__dla(void *)" -- 1st referenced by /usr/local/lib/gdal.a(ddfrecord.o).
ld32: ERROR 33 : Unresolved text symbol "__pure_virtual_called" -- 1st referenced by /usr/local/lib/gdal.a(ogr_srs_proj4.o).
ld32: ERROR 33 : Unresolved data symbol "type_info::__vtbl(void)" -- 1st referenced by /usr/local/lib/gdal.a(ogr_srs_proj4.o).
ld32: INFO 152: Output file removed because of error.
collect2: ld returned 2 exit status
*** Fehlercode 1 (bu21)
best regards, Andre
Mail scanned by virusscanner, Patternfile from 19 Nov 2003
