[Mapserver-users] MS4.0 and Raster (GeoTiff) assistance needed
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 20 10:05:24 EST 2003
Phil Shevlin wrote:
> I have a map with a number of layers working. I am trying to include a
> raster layer (.tif). When I include the layer:
> LAYER
> NAME "Test"
> STATUS ON
> DATA "E:/Inetpub/wwwroot/mapserver/raster/4424.tif"
> TYPE RASTER
> TEMPLATE "template_hi.html"
> END
> The map shows but the layer does not appear. I am assuming that it is a
> projection problem. My extent is in degrees:
> EXTENT -81.917574 26.569844 -81.755026 26.691756
> But the .tfw file appears otherwise:
> 4.00000000000000
> 0.00000000000000
> 0.00000000000000
> -4.00000000000000
> 669000.00000000000000
> 855000.00000000000000
> How do I go about including this layer? Or, can someone point me to some
> tutorials (I have found one that helps me).
Phil,
The raster is clearly in a different projection. You will need to establish
what coordinate system it is, and properly describe it with a PROJECTION block
in the layer. You will also need an appropriate lat/long projectio block for
the map level if your generated map is currently in lat/long.
To know the coordinate system you will have to look at your dataset and
talk to whoever you got it from.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
