[Mapserver-users] MS4.0 and Raster (GeoTiff) assistance needed
Ed McNierney
ed at topozone.com
Wed Nov 19 18:32:38 EST 2003
Phil -
If you can tell us what part of the Earth this raster file represents,
it will help us interpret the proper projection for it. It is clearly
NOT in degrees, and the 4.0 and -4.0 lines *probably* refer to meters.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
ed at topozone.com
-----Original Message-----
From: Phil Shevlin [mailto:pshevlin at cityftmyers.com]
Sent: Wednesday, November 19, 2003 5:04 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] MS4.0 and Raster (GeoTiff) assistance needed
I have a map with a number of layers working. I am trying to include a
raster layer (.tif). When I include the layer:
LAYER
NAME "Test"
STATUS ON
DATA "E:/Inetpub/wwwroot/mapserver/raster/4424.tif"
TYPE RASTER
TEMPLATE "template_hi.html"
END
The map shows but the layer does not appear. I am assuming that it is a
projection problem. My extent is in degrees:
EXTENT -81.917574 26.569844 -81.755026 26.691756
But the .tfw file appears otherwise:
4.00000000000000
0.00000000000000
0.00000000000000
-4.00000000000000
669000.00000000000000
855000.00000000000000
How do I go about including this layer? Or, can someone point me to
some
tutorials (I have found one that helps me).
Thanks
Phil Shevlin
I am using:
Win2K server
Mapserver 4.0
OGR => MapInfo .tab's
E:\Inetpub\wwwroot\cgi-bin>mapserv40 -v
MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
