[Mapserver-users] Error: msLoadMap():...Undefined symbol
(Solution)
Benjamin Thelen
thelen at ccgis.de
Thu Nov 20 11:29:23 EST 2003
Hello again,
it seems the problem came from the fact, that I use (what I forgot to tell),
mapserver 3.6.6, which is compiled with 50 classes as a default. I changed
that and everthing worked fine.
Indeed the error message was not very helpful. :-)
Benjamin
> Hello list,
> I moved a map-file from a FreeBSD-machine to a SuSE-Linux machine and
> suddenly I receive the following error message:
> http://192.168.2.116/cgi-bin/mapserv?map=/usr/home/umn/symbols.map&request=capabilities&wmtver=1.0.0
> msLoadMap(): General error message. Undefined symbol "ÿÿÿÿÿÿÿÿ" in class
> of layer Symbole.
> I changed the image-type and converted some from png to jpg. I removed
> some from the map-file, but all that is the error. On the FreeBSD-machine
> it is running well.
> I attached the map-file. Hopefully, somebody has an idea!?
> Thanks,
> Benjamin
