AW: [Mapserver-users] Problems with tiff
Christina Biakowski
christina.biakowski at ccgis.de
Fri Nov 21 03:21:53 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0011_01C3B010.E701B540
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hello Stefan,
just an idea, might be this is a problem of the assigned directory rights.
Check if within the path to the raster data for every directory the rights
are set to "x".
Christina
-----Ursprungliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Stefan
Wiegand
Gesendet: Donnerstag, 20. November 2003 15:48
An: woodbri at swoodbridge.com
Cc: mapserver-users at lists.gis.umn.edu
Betreff: Re: [Mapserver-users] Problems with tiff
Thank you Steve for this hint,
I renamed the *tfw to *.wld, but the mapserver also stops with the error
message
readWorldFile(): Unable to access file. Unable to open world file for
reading.
The cygwin mapserver accepts the *.tfw files for *.tiff without any
problems.
Mmmh
>Mapserver expects tiff world files to have the extension *.wld so
>rename your *.tfw to *.wld and you should be all set.
>-Steve W
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1226" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D013151908-21112003><FONT face=3DArial color=3D#0000ff =
size=3D2>Hello=20
Stefan,</FONT></SPAN></DIV>
size=3D2>just=20
an idea, might be this is a problem of the assigned directory rights. =
Check if=20
within the path to the raster data for every directory the rights are =
set to=20
"x".</FONT></SPAN></DIV>
<DIV><SPAN class=3D013151908-21112003></SPAN><FONT face=3DTahoma><FONT =
size=3D2><SPAN=20
class=3D013151908-21112003><FONT face=3DArial=20
color=3D#0000ff>Christina</FONT></SPAN></FONT></FONT></DIV>
<DIV><FONT face=3DTahoma><FONT size=3D2><SPAN=20
class=3D013151908-21112003> </SPAN></FONT></FONT></DIV>
class=3D013151908-21112003> </SPAN>-----Ursprüngliche=20
Nachricht-----<BR><B>Von:</B> mapserver-users-admin at lists.gis.umn.edu=20
[mailto:mapserver-users-admin at lists.gis.umn.edu]<B>Im Auftrag von =
</B>Stefan=20
Wiegand<BR><B>Gesendet:</B> Donnerstag, 20. November 2003 =
15:48<BR><B>An:</B>=20
woodbri at swoodbridge.com<BR><B>Cc:</B>=20
mapserver-users at lists.gis.umn.edu<BR><B>Betreff:</B> Re: =
[Mapserver-users]=20
Problems with tiff<BR><BR></DIV></FONT></FONT>
<BLOCKQUOTE><BR><FONT face=3D"Courier New" size=3D2>Thank you Steve for =
this hint,=20
</FONT><BR><BR><FONT face=3D"Courier New" size=3D2>I renamed the *tfw =
to *.wld,=20
but the mapserver also stops with the error message</FONT> =
<BR><BR><FONT=20
face=3D"Courier New" size=3D2>readWorldFile(): Unable to access file. =
Unable to=20
open world file for reading.</FONT> <BR><BR><FONT face=3D"Courier New" =
size=3D2>The cygwin mapserver accepts the *.tfw files for *.tiff =
without any=20
problems.</FONT> <BR><BR><FONT face=3D"Courier New" =
size=3D2>Mmmh</FONT>=20
<BR><BR><FONT face=3D"Courier New" size=3D2>>Mapserver expects tiff =
world files=20
to have the extension *.wld so <BR>>rename your *.tfw to *.wld and =
you=20
should be all set.<BR>><BR>>-Steve =
W<BR></BLOCKQUOTE></FONT></BODY></HTML>
------=_NextPart_000_0011_01C3B010.E701B540--
