[Mapserver-users] Distorted maps
Tyler Mitchell
TMitchell at lignum.com
Fri Nov 21 10:58:48 EST 2003
<FONT face=3D"Default Sans Serif, Verdana, Arial, Helvetica, sans-serif" si=
ze=3D2><DIV>You'll need to know the native projection that the data for tha=
t layer is in and make sure you set that layer's projection info in the map=
file. Then you would select a projection for the overall map. C=
an you tell us the projection your data is registered to? Can you pro=
vide your map file for us to critique :)</DIV><DIV> </DIV><DIV>Tyler</=
DIV><DIV><BR> </DIV><FONT color=3D#990099>-----mapserver-users-admin at l=
ists.gis.umn.edu wrote: -----<BR><BR></FONT>To: <mapserver-users at lists.g=
is.umn.edu><BR>From: "Benvenuto Bertacco" <benvenuto.bertacco at seat.it=
><BR>Sent by: mapserver-users-admin at lists.gis.umn.edu<BR>Date: 11/21/200=
3 03:18AM<BR>Subject: [Mapserver-users] Distorted maps<BR><BR><font face=3D=
"monospace" size=3D2>Hello,<BR>I need to use Mapserver to display maps very=
far from America, and it seems<BR>that the projection settings are choosen=
to optimize display of USA maps. In<BR>fact I get very distorted maps with=
geographical data located in Italy.<BR>Changing the projection system in t=
he map file doesn't sort any effect, also<BR>tried to change the proj=5Fdef=
.dat but either got no effect. Any help wuold be<BR>appreciated.<BR>Benvenu=
to<BR><BR>=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=
=5F<BR>Mapserver-users mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR=
><a href=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users" targ=
et=3Dblank>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a><BR=
></font></FONT>=
