R: [Mapserver-users] Distorted maps
Benvenuto Bertacco
benvenuto.bertacco at seat.it
Fri Nov 21 11:24:56 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_002E_01C3B054.620FF420
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_002F_01C3B054.620FF420"
------=_NextPart_001_002F_01C3B054.620FF420
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
charset="iso-8859-1"
Projection data is wgs84, navtech data. The mapfile requires more
information than that, but I don't know how to retrive it, although I
suppose that standard settings should work. Attached is the mapfile.
Many thanks
_____ =20
Da: Tyler Mitchell [mailto:TMitchell at lignum.com]=20
Inviato: venerd=EC 21 novembre 2003 16.59
A: Benvenuto Bertacco
Cc: mapserver-users at lists.gis.umn.edu
Oggetto: Re: [Mapserver-users] Distorted maps
You'll need to know the native projection that the data for that layer =
is in
and make sure you set that layer's projection info in the mapfile. Then =
you
would select a projection for the overall map. Can you tell us the
projection your data is registered to? Can you provide your map file =
for us
to critique :)
=20
Tyler
=20
-----mapserver-users-admin at lists.gis.umn.edu wrote: -----
To: <mapserver-users at lists.gis.umn.edu>
From: "Benvenuto Bertacco" <benvenuto.bertacco at seat.it>
Sent by: mapserver-users-admin at lists.gis.umn.edu
Date: 11/21/2003 03:18AM
Subject: [Mapserver-users] Distorted maps
Hello,
I need to use Mapserver to display maps very far from America, and it =
seems
that the projection settings are choosen to optimize display of USA =
maps. In
fact I get very distorted maps with geographical data located in Italy.
Changing the projection system in the map file doesn't sort any effect, =
also
tried to change the proj_def.dat but either got no effect. Any help =
wuold be
appreciated.
Benvenuto
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
=3D
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR></HEAD>
<BODY>
<DIV dir=3Dltr align=3Dleft><SPAN class=3D718351916-21112003><FONT =
face=3DArial=20
color=3D#0000ff size=3D2>Projection data is wgs84, navtech data. The =
mapfile=20
requires more information than that, but I don't know how to retrive it, =
<FONT=20
color=3D#000000>although I suppose that standard settings should work. =
Attached is=20
the mapfile.</FONT></FONT></SPAN></DIV>
face=3DArial=20
size=3D2>Many thanks</FONT></SPAN></DIV><BR>
<DIV class=3DOutlookMessageHeader lang=3Dit dir=3Dltr align=3Dleft>
<HR tabIndex=3D-1>
<FONT face=3DTahoma size=3D2><B>Da:</B> Tyler Mitchell =
<BR><B>Inviato:</B> venerd=EC 21 novembre 2003 16.59<BR><B>A:</B> =
Benvenuto=20
Bertacco<BR><B>Cc:</B> =
mapserver-users at lists.gis.umn.edu<BR><B>Oggetto:</B> Re:=20
[Mapserver-users] Distorted maps<BR></FONT><BR></DIV>
<DIV></DIV><FONT=20
face=3D"Default Sans Serif, Verdana, Arial, Helvetica, sans-serif" =
size=3D2>
<DIV>You'll need to know the native projection that the data for that =
layer is=20
in and make sure you set that layer's projection info in the =
mapfile. Then=20
you would select a projection for the overall map. Can you tell us =
the=20
projection your data is registered to? Can you provide your map =
file for=20
us to critique :)</DIV>
<DIV> </DIV>
<DIV>Tyler</DIV>
<DIV><BR> </DIV><FONT=20
color=3D#990099>-----mapserver-users-admin at lists.gis.umn.edu wrote:=20
-----<BR><BR></FONT>To: =
<mapserver-users at lists.gis.umn.edu><BR>From:=20
"Benvenuto Bertacco" <benvenuto.bertacco at seat.it><BR>Sent by:=20
mapserver-users-admin at lists.gis.umn.edu<BR>Date: 11/21/2003 =
03:18AM<BR>Subject:=20
[Mapserver-users] Distorted maps<BR><BR><FONT face=3Dmonospace =
size=3D2>Hello,<BR>I=20
need to use Mapserver to display maps very far from America, and it=20
seems<BR>that the projection settings are choosen to optimize display of =
USA=20
maps. In<BR>fact I get very distorted maps with geographical data =
located in=20
Italy.<BR>Changing the projection system in the map file doesn't sort =
any=20
effect, also<BR>tried to change the proj_def.dat but either got no =
effect. Any=20
help wuold=20
be<BR>appreciated.<BR>Benvenuto<BR><BR>__________________________________=
_____________<BR>Mapserver-users=20
mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR><A=20
href=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users"=20
target=3Dblank>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users<=
/A><BR></FONT></FONT>=3D</BODY></HTML>
------=_NextPart_001_002F_01C3B054.620FF420--
Content-Transfer-Encoding: 7bit
name="demo.map"
Content-Disposition: attachment;
filename="demo.map"
# Start of map file
NAME DEV
STATUS ON
SIZE 430 380
#SIZE 150 150
EXTENT 7.680 45.06 7.685 45.06
#EXTENT 7.680 45.06 7.683 45.06
#SIZE 1000 1000
#EXTENT 7.60 45.03 7.75 45.09
#UNITS METERS
DEBUG TRUE
SHAPEPATH "data"
IMAGECOLOR 189 198 206
PROJECTION
"proj=utm"
"ellps=WGS84"
"zone=15"
"towgs84=0,0,0"
"north"
"no_defs"
END
#OUTPUTFORMAT
# NAME gif
# DRIVER "GD/GIF"
# MIMETYPE "image/gif"
# IMAGEMODE PC256
# EXTENSION "gif"
#END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
#OUTPUTFORMAT
# NAME jpeg
# DRIVER "GD/JPEG"
# MIMETYPE "image/jpeg"
# IMAGEMODE RGB
# EXTENSION "jpg"
#END
#OUTPUTFORMAT
# NAME wbmp
# DRIVER "GD/WBMP"
# MIMETYPE "image/wbmp"
# IMAGEMODE PC256
# EXTENSION "wbmp"
#END
#OUTPUTFORMAT
# NAME swf
# DRIVER "SWF"
# MIMETYPE "application/x-shockwave-flash"
# EXTENSION "swf"
# IMAGEMODE PC256
# FORMATOPTION "OUTPUT_MOVIE=SINGLE"
#END
#IMAGETYPE SWF
IMAGETYPE PNG
#IMAGETYPE PDF
#PROJECTION
# proj=longlat
# ellps=WGS84
# datum=WGS84
# zone=50
# no_defs
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
#MINSCALE 1000
#MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
END
FONTSET "c:\windows\fonts\fonts.txt"
#REFERENCE
# IMAGE graphics/reference.gif
# EXTENT 393234.393701263 5205405.16440722 495769.579718949 5307959.02579127
# SIZE 120 120
# STATUS ON
# COLOR -1 -1 -1
# OUTLINECOLOR 255 0 0
#END
SYMBOL
NAME 'carto_line'
TYPE CARTOLINE
#Linecap - ROUND, SQUARE, TRIANGLE, BUTT - default BUTT
LINECAP BUTT
#Linejoin - ROUND, BEVEL, MITER - default NONE
LINEJOIN BEVEL
LINEJOINMAXSIZE 5
END
SYMBOL
NAME 'cline'
TYPE ellipse
POINTS
1 1
END
END
LAYER
NAME parchi_navtech
STATUS OFF
DATA parkcity_region
TYPE POLYGON
LABELITEM "NAME"
CLASS
LABEL
#ANGLE AUTO
#BUFFER 1
#PARTIALS FALSE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 255 255 255
END
STYLE
#COLOR 66 132 0
COLOR 77 199 63
ANTIALIAS TRUE
END
END
END # parchi navtech
LAYER
NAME aree_navtech
STATUS OFF
DATA landuseA_region
TYPE POLYGON
LABELITEM "NAME"
CLASS
LABEL
#ANGLE AUTO
#BUFFER 1
#PARTIALS FALSE
#FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION AUTO
SIZE 5
TYPE TRUETYPE
COLOR 255 255 255
END
STYLE
#COLOR 255 165 115
COLOR 179 181 81
ANTIALIAS TRUE
END
END
END # corsi d'acqua navtech
LAYER
NAME acqua_navtech
STATUS OFF
DATA waterwys_region
TYPE POLYGON
#LABELITEM "StNm_Base"
CLASS
STYLE
#COLOR 165 214 255
#COLOR 165 165 165
ANTIALIAS TRUE
COLOR 64 154 253
END
END
LAYER
NAME acqua1_navtech
STATUS OFF
DATA waterwys_polyline
TYPE LINE
CLASS
STYLE
SIZE 1
#COLOR 165 214 255
COLOR 64 154 253
ANTIALIAS TRUE
END
END
LAYER
NAME pedonali_navtech
STATUS OFF
DATA pedonali3_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\pedonali1.tab"
TYPE LINE
CLASS
STYLE
SYMBOL 'carto_line'
SIZE 3
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # pedonali navtech
#LAYER
# NAME vie_navtech
#MAXSCALE 600000
# STATUS OFF
# CONNECTIONTYPE OGR
# CONNECTION "c:\mapserver\itasca\data\vie_e_corsi.tab"
#DATA vie3_polyline
# END
# TYPE LINE
# CLASS
# STYLE
# SYMBOL 'carto_line'
# SIZE 9
#COLOR 181 222 255
# COLOR 120 140 255
# ANTIALIAS TRUE
# END
# END
#END # vie navtech
LAYER
NAME vie_navtech
#PROJECTION
# "proj=aeqd"
# "ellps=WGS60"
# "units=m"
# "towgs84=0,0,0"
# "no_defs"
#END
#MAXSCALE 600000
STATUS OFF
DATA vie3_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\vie1.tab"
TYPE LINE
CLASS
STYLE
SYMBOL 'carto_line'
SIZE 6
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # vie navtech
LAYER
NAME controviali_navtech
STATUS OFF
DATA controviali2_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\controviali1.tab"
TYPE LINE
CLASS
STYLE
SYMBOL 'carto_line'
SIZE 4
#COLOR 181 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # controviali navtech
LAYER
NAME controviali_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
TYPE LINE
CLASS
STYLE
SYMBOL 'carto_line'
SIZE 2
COLOR 255 255 255
ANTIALIAS TRUE
END
END
LAYER
NAME corsi_navtech
#MAXSCALE 600000
STATUS OFF
DATA corsi5_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\corsi1.tab"
TYPE LINE
CLASS
STYLE
SYMBOL 'carto_line'
SIZE 9
COLOR 120 140 255
ANTIALIAS TRUE
END
END
END # corsi navtech
LAYER
NAME importanti_navtech
STATUS OFF
DATA importanti5_polyline
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\importanti1.tab"
TYPE LINE
CLASS
STYLE
SYMBOL 'carto_line'
SIZE 8
#COLOR 156 202 156
COLOR 88 174 51
ANTIALIAS TRUE
END
END
END # importanti navtech
#LAYER
# NAME statali_navtech
# STATUS OFF
# CONNECTION "c:\mapserver\itasca\data\statali1.tab"
# TYPE LINE
# CLASS
# STYLE
# SIZE 8
#COLOR 156 202 156
# COLOR 88 174 51
# ANTIALIAS TRUE
# END
# END
#END # statali navtech
LAYER
NAME pedonali_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
TYPE LINE
LABELCACHE ON
CLASS
LABEL
ANGLE AUTO
FONT "verdana"
#BUFFER 1
#PARTIALS FALSE
ANTIALIAS TRUE
POSITION CC
SIZE 5
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
#SIZE 2
SIZE 3
#COLOR 217 222 255
COLOR 120 140 255
ANTIALIAS TRUE
END
END
LAYER
NAME vie_navtech2
#MAXSCALE 600000
STATUS OFF
DATA vie3_polyline
#CONNECTIONTYPE OGR
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 1
PARTIALS FALSE
FORCE TRUE
FONT "verdana"
ANTIALIAS TRUE
POSITION CC
SIZE 7
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 4
COLOR 255 255 255
ANTIALIAS TRUE
END
END
END # vie navtech
LAYER
NAME corsi_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 1
#PARTIALS FALSE
FONT "verdana"
#FORCE TRUE
ANTIALIAS TRUE
MINDISTANCE 2
POSITION CC
SIZE 7
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 7
COLOR 255 255 255
ANTIALIAS TRUE
END
END
END # corsi navtech
LAYER
NAME importanti_navtech2
STATUS OFF
#CONNECTIONTYPE OGR
LABELCACHE ON
TYPE LINE
CLASS
LABEL
ANGLE AUTO
BUFFER 1
#PARTIALS FALSE
FONT "verdana"
ANTIALIAS TRUE
MINDISTANCE 2
#FORCE TRUE
POSITION CC
SIZE 7
TYPE TRUETYPE
COLOR 0 0 0
END
STYLE
SYMBOL 'carto_line'
SIZE 4
#COLOR 255 255 132
COLOR 255 255 159
#color 255 255 255
ANTIALIAS TRUE
END
END
#LAYER
# NAME statali_navtech2
# STATUS OFF
# LABELITEM "StNm_Base"
# LABELCACHE ON
# TYPE LINE
# CLASS
# LABEL
# ANGLE AUTO
# BUFFER 1
# #PARTIALS FALSE
# FONT "verdana"
# ANTIALIAS TRUE
# MINDISTANCE 2
#FORCE TRUE
# POSITION CC
# SIZE 7
# TYPE TRUETYPE
# COLOR 0 0 0
# END
# STYLE
# SIZE 4
#COLOR 255 255 132
# COLOR 255 255 159
#color 255 255 255
# ANTIALIAS TRUE
# END
# END
#END
LAYER
NAME freccie_navtech
STATUS OFF
#CONNECTIONTYPE OGR
#CONNECTION "c:\mapserver\itasca\data\arrow.tab"
DATA arrow_font_point
TYPE POINT
CLASS
STYLE
SYMBOL 'cline'
size 2
COLOR 245 88 128
ANTIALIAS TRUE
END
END
END
END # Map File
------=_NextPart_000_002E_01C3B054.620FF420--
