[Mapserver-users] GRID problem using Mercator projection
Sebastian Albrecht
api at justapi.de
Mon Nov 24 10:39:58 EST 2003
Hello,
I would like to use the GRID feature projected to Mercator. The
problem is the grid goes far above the -90 and 90 degree latitudes.
The result is PROJ4 returns undefined values because every latitude
value greater or equal 90 or -90 is infinite.
Mapserver gets the values (I suppose 0) back and draws diagonal lines
across the whole world map meeting in lat=0 and lon=0.
Can I somehow limit the latitude of the GRID feature or is there
anything else I can do - except not using the GRID feature?
Regards,
Sebastian
Parts of my map file:
NAME Mapserver
STATUS ON
EXTENT -180 -85 180 85
SIZE 600 500
UNITS DD
SHAPEPATH "./data"
IMAGECOLOR 65 125 200
IMAGETYPE png
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
SYMBOL
NAME "dashed_line"
TYPE ellipse
POINTS 2 2 END
FILLED TRUE
STYLE 2 5 END
END
LAYER
NAME "grid"
TYPE LINE
STATUS default
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
GRID
MINARCS 2
MAXARCS 10
LABELFORMAT "%5.5f"
END
CLASS
SYMBOL "dashed_line"
COLOR 170 170 200
LABEL
TYPE BITMAP
SIZE SMALL
COLOR 200 200 230
SHADOWCOLOR 100 100 130
END
END
END
END # Map File
